27th March 2014, 10:51
Originally Posted by garyh
Hi Axel, how did you get the slots that neat?
Hi Gary, with an angle grinder, a very thin disc for cutting (1mm thick, for stainless steel), a thick disc for rounding off and a lot of patience ;-)
29th March 2014, 22:44
Alex - You car is a great reflection of the huge amount of effort you are putting into building it.
30th March 2014, 06:04
Just amazing how refined those slots make the whole thing look!
30th March 2014, 19:16
Thanks for the kind words, guys!
5th May 2014, 12:15
Some updates...
now come the bigger panels with moving further to the front :-)
Found out that the bigger panels are more fun, it is just the question how much you dome them!
It takes a long time to do the small ones because of my lack of experience, they all had reverse curvature...I need to do some courses...well, it is the first time I am doing this...
5th May 2014, 15:23
Looking good Axel, will this body come apart in sections? What do you do to the inside of panels to make it rigid?
5th May 2014, 18:45
Thanks Gary
I will keep fragments of the fiberglassbody as a supporting structure, it worked fine with the bonnet and will hopefully work with the body as well...
6th May 2014, 07:45
So,do you bond the li to the fibreglass?
6th May 2014, 09:07
Yes, I use Sikaflex, a very strong glue for automotive purpose, and the metal body is also partially screwed to the fiberglass substructure!
7th May 2014, 06:26
Originally Posted by Axel
... it is the first time I am doing this ...
Axel - The panels you are making are stunning.
But the fact you've never done this sort of work before is really amazing.
24th July 2014, 11:57
Whats happening Axel, on holiday?
25th July 2014, 06:28
Hi Gary, thanks for asking, my time is more for gardenwork now and my 8 months old son of course, such a cute little boy who makes me happy every day.
But I have some updates:
I managed to do the rear fenders and I was playing around with the airintakes, and I am still not happy with their shape, but I am getting to it.
Here are some pics:
I still have a little bump in the red circle, it needs some shrinking in that area to fix it, and then I need to transfer it to the left side. The intake was to big at my first attempt, and it did touch the cutline of the door, I made it smaller now and its getting better, but judge yourself!
25th July 2014, 08:05
Great work Axel, when your shaping those rear wings do you change the size of the anvil or have you just used the same one?
I can see the scoops take a lot of work, what bit are you not happy with/ is the return lip.
25th July 2014, 09:34
Thanks Gary, the wings were done with the english wheel, no hammering at all. I used the anvil with the most curvature at the beginning, and smoothed it out with lower anvils and used the most straight one at the end. I added the most curvature at the cutout for the wheel, the cutout was smaller at the beginning, and I cut it to tire size at the end after the most wheeling was done with the EW. Then I used the shrinker to bend it more in over the wheel, and smoothed it with the EW again. This process I did several times.
The upper flange was done with the shrinker/stretcher, and wheeled afterwards to smooth it.
Yes, the return lip was a pain in the a....still not smooth enough, the double curvature of the panel at all turned out pretty nice in fact...after some panels went in the bin ;-)
21st August 2014, 06:38
Ok, wife and kid are on vacation til tomorrow, so I had some time to continue with my car.
(You might notice I changed the airintakes panel again)
I removed the plastic sills first
the Dino sills have a 25mm flange, so I took some sheet metal, fixed a 25mm flat bar under the sheet, and rolled it with a soft upper with my EW, result is a pretty nice flange.
The sills are made in two pieces and welded together to get the needed length and the radius is rolled with a soft upper.
Then I started the front end with a metal "subframe". It was pretty difficult to find the right proportions, but it is getting closer and closer.
Because I don't have any measurements of the original car I had to do photo comparisons with photoshop...pretty helpful:
You can see it is getting pretty close. Unfortunately I have to modify the spaceframe at the upper front, it is too high, but I did it yesterday evening.
I would like to weld a 40mm half circle tube around the front airintake, but I have no bead roller, so I took a tube from an old party tent, cut it quickly in half, and modified it with the shrinker, pretty good result!
I have to do it again with an exact cut, and I think I have a good base for the rounded front air intake (I am pretty sure it is done a different way, and you experts have many other ideas ;-)).
I really like this very low perspective:
...thanks for watching! Any comments or help is much appreciated!
21st August 2014, 06:41
Here you can see my unprofessional try to make the round profiles for the front-intake.
I hammered 2" wide sheet metal around my tent pole with a rubber hammer, and it worked!
Then I added curvature with the shrinker on both sides, and atfterwards just one side to get the desired curvature in both directions
I need to smooth them out, guess I'll take the planishing hammer with low pressure for smoothing, but for the first try it looks pretty good!
Thanks for watching!
21st August 2014, 08:17
Carry on Axel, its one of the builds that gives me inspiration to keep building. I have a week in september to start on my build again... if i finish painting!
22nd August 2014, 06:36
Thanks Gary! Keep on Building! I am 52 years old now, and I guess I will never stop!
Yesterday I worked on the front-intkake again. I did the corners.
Right is were I started with, left is the result after using the planishing hammer and the shrinker.
The result is quite good, still some little dents, but I will smooth that out.
for the other side I just needed half the time, once you have figured out how it can be done, you are 200% faster.
22nd August 2014, 06:37
22nd August 2014, 07:56
Alex - I am another big fan of your build.
It is going to be a really special car when it is finished.
