Old 19th October 2013, 18:58
Originally Posted by neemo View Post
the Chevrolet LC470 Lucra has very similar lines to our very own A352
i like the colour scheme on the Chevrolet Lucra LC470
very lotus esque
I am liking that Love the "kidney bean" slot mag wheels in black.
Old 19th October 2013, 19:30
jmc14 jmc14 is offline
The Lucra started out as a "replica" of a 58 Lister Knobbly. It was designed and built by Chuck Beck of Porsche 550 Spyder fame. I'm pretty sure that Lucra took over the project. They have a new version with a different hood.
I built one of the first kits of this car from Beck. Nice looking. Very cramped cockpit and foot boxes. Used narrowed C4 Corvette suspension. The car was advertised as being under 1900lbs. I built as light as possible, even left out seats and mine came in at 2200lbs.
Old 19th October 2013, 19:58
Hi John
Good to hear from you again, your knowledge is extensive. How is your MX5/Miata project going?
Old 19th October 2013, 23:27
Hello Chris, It's been slow. I've only been able to work on it every few weeks or so. And, I've had a bunch of false starts as I've been zeroing in on the final details.
I decided to go with a dedicated frame. It combines a backbone with a space frame design. I wanted to be able to have functioning doors. That's the reason for the backbone. The frame is skinned with aluminum then the body will drop on. The wheelbase is 95 inches. Then I shortened the drive shaft and torque arm by 8 inches. This let me get 53% rear weight and get the engine lower as well.
I have the frame done. The first one I did with out doors and just skinned it with aluminum to make a little track car. The 2nd one has doors. I'm working on the body for that now. The body is a work in progress. The scoop will be changed along with wheel arches, fender arches, ect.
I wish that I had your photo shop skills!!!!!
I hope that you are having great success. John
Old 13th November 2013, 16:46
patoune's Avatar
patoune patoune is offline
patoune is on a distinguished road
Last step… MOT to morrow !... I am confident.
Old 13th November 2013, 18:08
Looks great! Good luck with the MOT
Old 13th November 2013, 19:42
Down&Out's Avatar
Down&Out Down&Out is offline
Whilst i love your A352's and your work and progress rate is astounding, they definitely need bigger wheels/tyres or a bit of lowering!
Only my opinion, but there you are. Best of luck with the MOT of course, it'll fly through i bet.
Old 14th November 2013, 18:45
patoune's Avatar
MOT obtain !
Old 12th December 2013, 17:32
patoune's Avatar
Start of hibernation !...
Old 12th December 2013, 18:20
casamolino casamolino is online now
We can all dream! is that a Ford Anglia on the right hand side? my first car a 1966 105E , the engine seized after the sump plug fell out , making me unpopular with the police as it happened on the Runcorn-Widnes bridge in the rush hour , Geoff .
Old 15th December 2013, 21:38
scimjim's Avatar
scimjim scimjim is offline
Love the wheels on these two - are they banded steels or off the shelf?
Old 15th December 2013, 22:17
Little Red Car Little Red Car is offline
Little Red Car is on a distinguished road
They're standard TR6 15" steels. They only came in 4x4.5" (4x114.3mm) PCD so would require adapters to fit the Spitfire 4x3.75" (4x95.25mm) PCD hubs.
Old 15th December 2013, 22:19
Patoune, how did you modify your Euro dummy chrome spinners? I bought the same set but am unhappy with the way they mount: too easily broken. Did you put an extra bolt/pin through yours to secure them better?
Thank you.
Old 15th December 2013, 23:04
scimjim's Avatar
ah - thanks (I've seen them fitted to Scimitar GTEs). I was just looking at the possibility of fitting the 352 body to an SS1 chassis
Old 16th December 2013, 13:16
Default Wheels
Hi scimjim, if you want to stay with standard Triumph wheels, you could go the route I have gone.
I used basic Triumph solid disc wheels, drilled out all the holes, and the finished product fills out the wheel arches and I think, looks quite presentable.
The biggest drawback is that theses wheels in 5.5J form are hard to find these days, I was lucky enough to have hoarded them for years!
Take look at the following pics.
Old 16th December 2013, 19:02
patoune's Avatar
Thank you.
Old 16th December 2013, 19:09
Thanks Patoune, that's very helpful.
Old 22nd January 2014, 17:16
patoune's Avatar
Number 4
Color will be : METALLIC GREY
http://smg.photobucket.com/albums/v1...ps0a6edf0d.jpg
Old 22nd January 2014, 20:11
adventuresoftimtim adventuresoftimtim is offline
adventuresoftimtim is on a distinguished road
Very nice!!
I had thought that one in metallic grey would give it a classy modern twist!
Old 29th January 2014, 18:52
patoune's Avatar
Out this morning...
http://smg.photobucket.com/albums/v1...psb55c8c2f.jpg
