Old 21st May 2019, 11:09
Hughandjen Hughandjen is offline
Hughandjen is on a distinguished road
Default Steering wheel airbag
Hi guys
I am sure I read a thread on here about fitting a wooden steering wheel and fooling the airbag sensor with use of some resistors. I have searched and can’t find the thread😩
Mine in an early car with o e stage airbag. What resistance do I need to put in series between the two airbag wires
Old 21st May 2019, 12:16
You can also just pull the airbag sensor box from behind the centre console. Pictures from mine on here somewhere
Old 21st May 2019, 12:45
I wrongly thought that I had 2 airbags. But now I understand that the passenger side doesn’t have one. Now I’ve built the dash so can’t get to the module so will do the resistor solution.
Old 21st May 2019, 17:09
IanA's Avatar
IanA IanA is offline
It's worth joining the Z Register for this sort of stuff as well.
Old 21st May 2019, 17:28
Old 22nd May 2019, 04:37
Welshkiwi Welshkiwi is offline
Welshkiwi is on a distinguished road
Hi Hugh,
3.3 ohm resistor for each squib that you need to isolate. I had a Two stage airbag so needed to go across the two circuits, two resistors. Check your wires coming out and trace to work out horn and airbag/s as appropriate.
Hope this helps. Cheers.
Oh and remember that faults in the SRS system will hard fault until reset by a scan tool. (Light will stay on even if picking up resistor until cleared)
Old 22nd May 2019, 12:24
Originally Posted by Welshkiwi View Post
Hi Hugh,
Thank you that’s great
Old 22nd May 2019, 15:04
smash smash is offline
You'll need air bag warning reset tool b800 cheap enough on eBay. I would put a fuse in line with resister.
Old 22nd May 2019, 16:27
What size fuse would you use?
Old 22nd May 2019, 16:50
Ah! Got me there lol I just bought pre built version off eBay which had a fuse as part of it. Just checked on eBay- it was a yellow sealed unit with 2 amp fuse. Fuse is there to Stop resistor blowing if the airbag is triggered
https://rover.ebay.com/rover/0/0/0?m...2F261532857253
Old 22nd May 2019, 18:55
molleur molleur is offline
Thanks for that link Smash! Just ordered one as well.
Old 23rd May 2019, 08:15
Here is a picture of mine when I was remodelling the centre console.
https://photos.app.goo.gl/wAjcsZRqrtzkY3mz7
The airbag sensor box was about where the heater dial is in the picture
