Old 24th May 2018, 15:52
Bonds Bonds is offline
Bonds is on a distinguished road
Default Drum brake adjuster
Hello all, I'm new here, I have just aquired my first kit car, it's a ford scorehill magic on a 1980 ford cortina chassis, wanting to adjust the drum brakes I've found no adjuster of any kind in the drum, though the drum and shoes are only two years old, my question is, can I substitute the spreader bar at the top just below the piston for a serrated wheel type of adjuster, or can another type of adjuster work, there's no adjustment on the hand brake cable or assembly either, Thanks in advance for any help.
Old 25th May 2018, 11:15
peterux's Avatar
peterux peterux is offline
The short answer is ..I don't know but I'd get yourself a used Haynes workshop manual and see how the Cortina brakes are supposed to be assembled and adjusted.
Fitting non-standard parts or modifying brakes is not recommended.
I expect there is an easy standard solution.
