Old 14th May 2007, 19:48
peterux's Avatar
peterux peterux is offline
Default SVA and E numbers on Lights
Here is a general question about E numbers on lights and the SVA test.
I've read the SVA manual but can't figure out if it is compulsary to have E approval marks on your lights to pass the SVA test.
Do we any SVA testers that view this forum that could comment, maybe?
I have some front indicators (ex-motor bike) which are not 'e' marked.
Will they fail?
Old 14th May 2007, 20:11
JG's Avatar
JG JG is offline
Big Cheese
JG has disabled reputation
MAPPER!
Old 14th May 2007, 20:43
Patrick's Avatar
Patrick Patrick is offline
Thats a good question, I've bought some fog / reverse lights that dont have E marks. I've put some different one on for now!
Old 22nd July 2007, 21:34
Patrick's Avatar
Want to bring this one back up, I've got clear side repeaters which are nice and smooth so no edge radius problems but no E mark, not sure if I should put those on or the E marked ones with a sharper edge.
Also any ideas if these indicators will pass? I've got some others that I can put on with E marks:
and the repeaters:
Old 23rd July 2007, 06:11
limpabit's Avatar
limpabit limpabit is offline
I'll check my side repeaters tonight Patrick. They look the same as mine. Will check for an 'E' mark. I got mine from Marlin.
Old 23rd July 2007, 08:31
Patrick's Avatar
Thanks, I got mine for SVC at Stoneleigh this year!
Old 23rd July 2007, 18:08
limpabit's Avatar
Hi Patrick.
Mine do not have the 'E' mark on the side repeaters.
Old 24th July 2007, 07:03
Patrick's Avatar
Excellent, I will put those ones on Thanks very much for checking.
Old 25th July 2007, 20:25
andy andy is offline
Kit Car Dreamer
andy is on a distinguished road
I think the headlights have to be emarked but the rest are up to the SVA inspector to judge if they are adequate......
I know this is the case for the rear as I purchased rear lights as they were apparently E marked and when they arrived they were not... So I phoned up the nearest SVA centre for clarification.
The only problem is that if the lights are not an E marked cluster then they have to conform to certain distant regs such as brake light must be 200mm+ from the rear fog light.
Old 26th July 2007, 13:43
Patrick's Avatar
my headlights, spot lights & rear lights are all E marked. I've put e marked fog and reverse on for the test.
I'll put the none e marked indicators and repeaters on for the test and see what happens, but looks like it will be fine! Thanks guys
Old 26th July 2007, 20:10
peterux's Avatar
I've read the manual a number of times and it says "e" marked or emit light of a similar brightness.
If they are "E" marked, i guess there is no debate. If they are not marked, it is down to the examiners discretion. My plan is to use some cheap "e" marked side repeaters and then replace with my nice non-"e" marked ones.
My theory is that the less there is to his descretion, the easier it is for the examiner to give it a pass!
I bought another set of front indicators recently to get the "e" marks and now find they are only 5 watt bulbs! Normal car indicators are 21 watt, so now i'm not sure which is best?
Bright but not "e" marked?
Old 29th July 2007, 20:34
peterux's Avatar
Found some nice small 12 volt 23 Watt bulbs for motor bikes in Halfords yesterday, so now I have "e" marks and nice bright 23Watt bulbs !
Old 2nd August 2007, 15:09
Vindi_Andy's Avatar
Vindi_Andy Vindi_Andy is offline
Vindi_Andy is on a distinguished road
saw some brilliant looking mirrors with repeaters built in at stoneleigh and I want to fit them but they didnt appear to be SVA compliant so not sure what to do
Combined price of nice mirrors and side repeaters is about the same as the mirrors witht them built in so dont want to be buying mirrors and repeaters twice so have similar problem
Old 2nd August 2007, 15:25
Patrick's Avatar
Halfords do cheap mirrors for about £12 IIRC - they use a universal hole pattern so you can put the ones on you want, remove then put the halfords ones on. That's the plan with the Sportster as I have nice bullet mirrors that won't pass SVA. You'd then have to source some repeaters which you could sell on after the test. Same with the mirrors, there have to be many builders out there that will need a set of mirrors or repeaters just for SVA.
Old 3rd August 2007, 15:32
Vindi_Andy's Avatar
Problem with that is Id be left with a hole in the bonnet where the repeaters had been and it would look a bit daft with 2 sets of repeaters
Old 3rd August 2007, 15:35
Patrick's Avatar
ahh I didn't think about the holes.
What causes the mirrors with repeaters to fail? Glass size, sharp edges, movement of the mirror?
Nothing can be done about glass size, but edges could be covered with some small rubber edging!
Old 5th August 2007, 09:14
mapper mapper is offline
mapper is on a distinguished road
Sorry John and fell's.I seem to have missed this thread,Can anyone post a pickie of the mirrors.
Mapper
Old 6th August 2007, 14:39
Vindi_Andy's Avatar
not sure that they are definately a fail but I would be seriously bombed if i got to the test and that was the only thing it failed on
Just wondering as I saw them on the car builder solutions stand at stoneleigh and thought they were the dogs danglies
Old 6th August 2007, 14:50
Patrick's Avatar
Was it these ones?
CARBON MIRROR WITH INDICATOR Pre-wired LED indicators. SVA OK
Carbon effect body with rubber shrouded steel stalk. Convex glass size 135mm x 77mm. Glass swivels in housing. Base size 70mm x 28mm 2 screw fixing. Overall size 260mm
http://www.nfauto.co.uk/mirror1.htm
Old 6th August 2007, 21:09
Vindi_Andy's Avatar
thats them but at stoneleigh they didnt say they were SVA ok but have just answered that one
Thanks patrick
