Old 28th June 2019, 02:21
molleur molleur is online now
Why not use dzus fasteners and make it removable..
Unless I misunderstood your post.
Old 28th June 2019, 09:14
deggsy deggsy is offline
Molleur
Thanks for the reply yes it will be removable i'll be using some sort of clips.
cheers
Deggsy
Old 29th June 2019, 07:00
Deggsy - Your aluminium half tonneau cover will look spectacular.
Good luck with all the drilling and riveting required.
Old 9th July 2019, 20:57
Default hard cover
Almost finished now all the supports and alloy sheet have been made and drilled fixed with over 200 pop rivets.
The panel was then etch primed and all the rivets heads filled and flatted to look like old fashion rivets rather than the pop ones.
Etch primed again then the same process for the end fillets.
The fillets will be removable, ready for painting now I have left six rivets out into which i will fit some m4x30mm button head bolts which will have tabs on them to hold the panel in place if that isn't secure enough then i'll fit some boot locks
Cheers back soon.
Old 9th July 2019, 21:33
fantastic job, well done!
Old 9th July 2019, 22:16
You filled the heads of 200 rivets!
Rather you than me, but great job
Old 10th July 2019, 17:08
Yep took me the best part of two days and there are still a few that have to be re done. doh!
Old 24th August 2019, 19:23
Not a lot been happening lately but I finally took the plunge and bought a compressor the car is now up on ramps ready to be flatted back for primer. I have also been cleaning the garage ready for painting the car
I am hoping to start spraying it next week if all goes well
I will post photos when done.
Old 24th August 2019, 22:46
Best of luck with the paint, make the most of the warm dry weather, its about as good as it gets for painting at home !
Old 28th August 2019, 17:23
Default Paint
The car has now had two coats of high build primer which showed up a few flaws which we missed these have now been stoppered flatted and re sprayed.
I am hoping for nicer weather tomorrow to apply the top coats
Old 29th August 2019, 09:38
kon kon is offline
Looking good. Am I going mad tho... those pics look like they are the same pics from the 24th?
Old 29th August 2019, 18:07
Hmmm my apologies you are right i don't know what happened there the photos I took seem to have vanished into the either.
Never mind I will post some of the finished paint job in the next day or two.
Old 31st August 2019, 07:11
Hope the painting is going well and I'm looking forward to seeing it in colour.
Old 31st August 2019, 10:11
Default painting finished
Finished the painting late last night there are a few small runs but nothing major I will leave it a few days to fully cure then start on butting it all back together.
I do have a small confession to make I didn't spray it myself my nephew volunteered and as he has sprayed a half dozen or so in the past who was I to refuse his kind offer.
Old 31st August 2019, 10:13
And thanks for the encouragement guys.
Old 31st August 2019, 13:54
looking good!
Old 8th September 2019, 19:50
I have started putting it all back together some of the lights are in place.
For some reason the doors and boot lid don't line up any more incredible the difference a coat or two of paint makes! also the boot lid support bracket which is/was bonded on decided to un-bond itself twice I am looking into other bonding materials as I don't want to drill a hole in the lid and bolt it in place.
It should look a bit like this when they are fitted properly
Old 8th September 2019, 20:41
Very nice!
Make sure to remove ALL of the old bonding material.
I have been using UPOL Tiger Seal with success.
Old 9th September 2019, 01:37
Munky Munky is offline
That looks fantastic!
Hats off to you sir!
Old 11th September 2019, 14:59
Deggsy - Your car is coming together very nicely.
I am sure it will look even better when you get the chance to roll it out into natural light.
Good luck with getting everything to fit as nicely as you would like.
Although, I recently posted these photos on the Miglia forum….
As the key thing to remember is that back in the ‘50s, these cars were built like this…
Not like this.
So if you do end up with some odd panel gaps, just say the body shell for the car was hand built.
