Old 1st August 2017, 15:10
chaterpedal's Avatar
chaterpedal chaterpedal is offline
chaterpedal is on a distinguished road
Default steering rod gaiters
can you help, my sportster is the x terry Dutton, built late 1990's the gaiters on the steering rod have split and I need new ones but unable to find out what they are.
Old 2nd August 2017, 13:25
Grey V8 Pete's Avatar
Grey V8 Pete Grey V8 Pete is offline
Grey V8 Pete is on a distinguished road
If they are O/E ford ones, have a look at the outer conical ends and there should be a raised part number moulded on. Something like "86BB- etc. Then type that number into Google and you should find what model they were for and a supplier.
CBS also do universal ones but check that the max outside diameter as it may foul chassis parts if too large. Peter.
Old 2nd August 2017, 17:55
peterux peterux is online now
Not sure if Marlin used more than one type of rack but my 2004 Sportster used a recon rack from a Ford P100.
Have look at the dimensions in this ebay advert and see if they match your existing boots.
http://www.ebay.co.uk/itm/FORD-P100-...AAAOSwrhBZJaoJ
Old 3rd August 2017, 17:18
Default sportster gaiters
checked and no numbers
Old 3rd August 2017, 18:59
Mike Mike is offline
The Sportster shares the same basic chassis as the Cabrio which also used the Ford Sierra non power steering rack.
Its a safe bet yours will be the Ford P100.
Old 4th August 2017, 12:42
Smile gaiters
many thanks
Old 7th August 2017, 15:28
Smile more help gaiters
thank you all, O now know they are sierra p100, have taken my old gaiters off and find they are not a pair, drivers side diam. 55mm length 155,passenger side Diam.35mm length 210mm, any ideas ?
Old 7th August 2017, 21:25
These fit all models of Sierra steering racks, and at 9.99, you can't go wrong:
http://www.ebay.co.uk/itm/Ford-Sierr...EAAMXQrC9SalMG
Old 26th August 2017, 12:48
have now changed the gaiters and new ends as well, anyone advise what te steering set up is in case I moved a wheel?
