Old 29th June 2018, 09:43
Barber's Avatar
Barber Barber is offline
Default Enforced Pause
What with holidays and family engagements around the country I have had little time to do anything apart from seal the dashboard together, not much visible difference to the previous photos.
My Z3 has a yaw sensor problem, and has been with the garage for 3 weeks as they have had problems getting the sensor from BMW. Today they were sent a longitudenal sensor and not the rotational one, so more delays. As I don't have the car to hand, I can't check the colour of the vinyl covering for the dashboard is right, so am pretty much hamstrung on progress there until I get the car back.
Paintwise, I need to talk to Chris to get a colour sample of what the gelcoat will look like in green before I spend more money on can samples.
But I am enjoying the sunshine anyway.
Old 29th June 2018, 14:15
Jaguartvr's Avatar
Stick with the repulsive green, it will spur you on to finish the car and get it painted. If it looks OKish you don't have the same desire to get it pained properly which is a big mistake.
Old 29th June 2018, 14:45
Barber's Avatar
You know me too well, I was hoping that I may get away with a worn out, served its purpose kind of effect.
Old 8th July 2018, 17:39
Jaguartvr's Avatar
Any further updates/photo's of the repulsive green one?
How about dash progress?
Old 10th July 2018, 13:24
Barber's Avatar
Default Progress, or not
My Z3 is still with the garage, it is taking an age to get the sensor. So long as it is there, I cannot check the vinyl colour against the dash, so enforced sitting in the garden enjoying the sunshine.
Nothing to report on the body.
Old 10th July 2018, 19:04
peterux's Avatar
peterux peterux is offline
Originally Posted by Barber View Post
My Z3 is still with the garage, it is taking an age to get the sensor. .........
That sounds very suspicious to me. I built a BMW based kit car and I'm currently installing a BMW M52 engine in my Sabre and all my experiences with BMW parts department have been truly excellent. Prompt (usually less than 48 hours), efficient, courteous and accurate. Of course, there could be exceptions but I've never had a problem.
And you can look up spare part numbers using this website...
https://www.realoem.com/bmw/enUS/select (But do ignore the adverts)
Just type in your VIN and then drill down to find the part numbers.
I would be challenging your garage on what issues they are having
Old 8th August 2018, 11:00
Barber's Avatar
Default Nothing much happening at the moment
Chris has been labouring in the hell that is GRP work during the recent (and ongoing) heatwave. Last time we spoke, he was due to collect a Micra screen as a possible solution for the rear. Not much else to report on that.
The Z3 yaw sensor issue is dragging on. The indy BMW garage uses a local BMW dealership for parts supply. The OEM for the part has changed a couple of times, and searching round the internet, they are not common parts. The Euro holiday shutdowns don't help either. Result is that no part supplied yet, after the initial long delay then sending wrong part. The garage had to send the part of my car so that they could verify the correct part number from the first OEM supplier.
As it happens, I haven't had much time to do work anyway, and certainly would not have relished doing stuff in the temperatures we have been experiencing, so whilst a little frustrated, not desperately so.
Reading that back, goodness, it's dull, sorry.
Old 8th August 2018, 12:42
froggyman's Avatar
It may be dull at the moment but I am sure it will get a lot more interesting in the near future.
Old 10th August 2018, 00:46
Gamphy Gamphy is offline
Gamphy is on a distinguished road
Hi Barber on the subject of rear windows, have a look at the 1 series Beemer, following one today send it's got a nice radius o the sides and reasonably short in height.
Old 10th August 2018, 07:32
Barber's Avatar
Thanks, will have a look. Chris's thinking was that as the Z3gato is a coupe, a deeper screen would give more visibility. But the width and curve are primary considerations.
Old 10th August 2018, 19:03
molleur molleur is offline
Same with the 250, can't find a screen to suit. The Grassbank seems the only option.
Old 10th August 2018, 19:24
Barber's Avatar
The Z3gato uses a modified 275 roof, so is wider than the 250. Probably the Grass all one will not be wife enough but I will investigate.
Old 14th August 2018, 19:07
Barber's Avatar
Chris has got the Micra screen, and dropped onto the hole cut for the Alpha ft screen, it looks like it can work. Needs moving a couple of inches up, and some work to the sides and boot. Nothing more to see for a couple of weeks.
Old 14th August 2018, 20:07
IanA's Avatar
IanA IanA is offline
..it looks like it can work...
Looks rather good actually.
Old 14th August 2018, 20:22
That does look good
Old 15th August 2018, 16:05
kon kon is offline
kon is on a distinguished road
Yea, that does fit rather nicely. Has it created a double-hump on the top of the car, due to the curce of the screen, and the fact that it's usually more upright in a micra? cant quite see in that pic.. i'd guess it would be more apparent in a side-on photo, rather than rear quarter.
Old 15th August 2018, 17:08
Barber's Avatar
Let's just say it will take some work around it. But probably the best all round shape, so over to Chris and Dan for a bit of magic.
Old 16th August 2018, 13:14
Barber's Avatar
here is the image from the link
If the screen is moved up a couple of inches, the lines down to the boot can be re-aligned. Chris said that he had to nip the 275 roof in at the back for Welshkiwis car. This formed the base for the Z3gato, but it will have to be moved back out to accommodate the screen at the top.
So the whole of the back from the roof down to the boot will need re-working. But it is going to be worth the wait. The black surround to the screen is not the best, but needs must if we want to have a stock production solution that doesn't cost the earth.
Old 16th August 2018, 14:13
I quite like the black surround, still gives a production car feeling, even if it is a few decades out. I am really looking forward to seeing what your going to do around the window.
Old 16th August 2018, 15:30
Looks pretty good to me but wouldn't be a problem on a black car anyway.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
