Old 21st July 2020, 09:44
Default Coming soon ... Formosa 236 CM
I'm currently modifying a body so that it can be used on an early Locost chassis ... It'll be 93" wheelbase with rear seating position as is standard with a 7 style car .... Only suitable for the narrower live axled cars , which I know limits donors a little , but I won't compromise my narrow styling to accommodate wider donors at present ....
Old 21st July 2020, 09:56
When you think about it there are quite a few donor options with the Escort rear axle. Locost, Locust, Early Westfield, MK, Dutton. The early, narrow Triumph based Robin Hoods and probably others.
Old 22nd August 2020, 14:16
You've done a great job on this one Gary. The facebook photo's and info show just how well the concept works. Similar to my 250 Testarossa project with a Locost donor but this time the body is designed to go over a Seven chassis ! The seating position in my TR was basically bolt upright, where as in your car far more laid back as per a Seven style car. Its on my bucket list of car builds to do !!
Old 22nd August 2020, 14:37
Could build it to look a little like this .....
Old 22nd August 2020, 15:09
redratbike's Avatar
What are they????
Based on what
Old 22nd August 2020, 15:15
Its an Evanta DB4 Barchetta. They were going to build 99 examples but I don't know if they ever did. It was a replica of a one off Aston Martin prototype.
Old 22nd August 2020, 15:16
redratbike's Avatar
Thank you .. never seen one before
Old 22nd August 2020, 15:20
It shares a very similar outline, even the wheel base is the same as Gary's new car at 93" !
Old 22nd August 2020, 18:53
smash smash is offline
Great idea! Looks cool and plentiful donors
Old 24th August 2020, 19:40
Bodies now available and both bonnet options fit .. Also LHD and RHD format available ..... 2450
Old 24th August 2020, 21:55
molleur molleur is online now
looks good!
Old 12th September 2020, 17:41
A good deal to be had here if its still available, rolling chassis complete with the body as shown above.
