Old 29th November 2011, 09:22
Default Chassis treating/painting/rust proofing
Once you get your chassis into a reasonable state what do you paint or coat it in?
Assuming you haven't managed to remove every speck of rust I guess there has to be some kind of rust treatment rather than simply slapping paint onto a slightly rusty chassis.
Anyone used POR-15?
They speak very highly of it in the adverts and the video looks like it bonds well (http://www.holden.co.uk/displayProdu...5&brandCode=Z7) as he hits the exhaust with a hammer at the end of the clip.
Old 29th November 2011, 09:39
GreatOldOne's Avatar
I've used POR-15 on my Marlin:
http://www.greatoldone.co.uk/Gooster...nt_begin!.html
http://www.greatoldone.co.uk/Gooster...kiving__2.html
It's brilliant stuff. Hard as nails, and as easy to use as Hammerite. I've done my rear suspension, diff, drive shafts and other bits and bobs with it.
You can also get it from Frosts:
http://www.frost.co.uk/
Along with POR15 thinners.
Old 29th November 2011, 09:43
In the video they show the marine clean then the metal prep and then the POR-15 rust paint. I assume you need to go through those stages.
Any idea how much I will need to do a TVR chassis and other bits that would benefit?
Old 29th November 2011, 10:02
I used Jenolite as I'd used to it on an old Capri i once had and i knew it worked "for me"
Then it was a case of painting with Chassis Black paint.
Old 29th November 2011, 10:11
You don't need to use marine clean. Or metal prep. I did use metal prep in earlier on in my resto, but didn't bother later on. As long as the metal you're painting is grease free, you can paint direct to metal.
Old 29th November 2011, 11:45
cbjroms cbjroms is offline
cbjroms is on a distinguished road
I had my Herald chassis blasted and then used POR15.
I did use the Marine Clean & Metal Ready first as I had read reports of the POR15 peeling-off when put onto bare metal.
POR15 is a little tricky in that it claims there to be a narrow window of time between coats unless you opt to prime again. I did actually tend to use the POR15 self-etch primer as I left the chassis some days between coats.
The POR15 itself gave a very imrpressive finish - hard and shiny (gloss black). I then used the silver topcoat and feel that it has a much softer (ie easily scraped) finish.
Just my thoughts.
Chris
Old 29th November 2011, 14:51
Nick59 Nick59 is offline
Nick59 is on a distinguished road
I used Bilt Hamber products :- link below
http://www.bilthamber.com/search-pro...sion%20Removal
I have previously used De-ox gel & dipping bath and Hydrate 80 on the chassis on my build prior to Hammerite. Its reasonable cheap and I left it on my TVR chassis and components for about 5yrs without painting we no sign of rust "re-growth"
They also do an Epoxy Mastic 2 part chassis paint which is the dogs naggers (but I already had a gallon of Hammerite)
Must say I am going off Hammerite it doesn`t seem to be as good as it used to....I think its all those tree huggers that have forced them to remove those chemicals that actually worked!
Bring back lead based paint!
Old 2nd December 2011, 07:34
mashtun mashtun is offline
mashtun is on a distinguished road
I used POR-15 last year when repainting my Cabrio chassis. I used the grey colour (three coats, I think, working on smallish areas at a time) and then put Chassis Black on top. The POR-15 does seem remarkably tough (I've got various suspension bits that have POR-15 on them but haven't been top-coated) but I've chipped the Chassis Black on a couple of thinnish edges - made me think I'll put something over the top of that where stone chips are liable to hit.
As for coverage, I think the coverage rates they claim were about right. You could have fun working out the surface area of your TVR chassis though
Old 5th October 2012, 15:10
Anyone used POR-15?
when you use the Metal Ready, it says to keep it damp for 20mins... what about a whole chassis?
Old 5th October 2012, 17:09
I used POR-15 on the Scimi chassis. No metal etch but did small areas at a time so each took about 20 minutes
