Old 10th May 2013, 22:03
Default A352 Speedster?
If I am being totally honest, when I made the the stands on which the A352 mock up shell sat on at Stoneleigh, I made them a bit too short!! But, as often happens, the resulting car looked great
Looking at the shell sitting over the wheels started me thinking. The car can be built and driven like this, if 4" is removed from the sills. The Spitfire bulkhead will need to be section and welded as will the rear bulkhead above the petrol tank, which may need to be moved to a lower position in the boot.
Engine clearance may be a problem, but this can be simply solved by fittting a flat 4 engine from a Subaru. Watch this space..........
Old 11th May 2013, 07:15
Down&Out's Avatar
Down&Out Down&Out is offline
Cacking hell. That looks insane.
I always knew these would look better sitting lower on wires, you're making me want one again!
Old 11th May 2013, 07:46
Hi Chris,
I've posted photos of your "slammed" A352 both here & "next door", and it always gets a great reaction...
That slammed 352 looks the nuts
Now that's what I call a stance! I 'king love it!
So I'm looking forward to seeing this develop.
Old 12th May 2013, 19:19
Hi Chris,
Thanks Paul, good to meet you at Stoneleigh. I am wondering if can get away with 13" wires as the car is sooooo looooow? It would help to lower it a little more too
Old 13th May 2013, 06:32
Nice to meet you too Chris.
But forget the 13" wheels, a man of your skills could fit air ride suspension!
Then you could really slam it to the ground...
Full details of this epic build here:
http://www.rodsnsods.co.uk/forum/gar...uild-pics-8642
