Old 11th December 2013, 15:12
GJGB GJGB is offline
Kit Car Dreamer
GJGB is on a distinguished road
Default GTR body lift with hoist?
Hi all,
I'd like to test fit the body onto the chassis now all the running gear is in place but am not keen on the "four strong blokes, one on each wheel arch" approach as it looks a bit under-controlled.
I believe I saw pics on somebody's build log of the body suspended from a hoist?
That looks to be a more controlled way to lower the body and see what fouls etc.
Anyone want to tell me how they got their body onto the metal? If you hoisted it, what lifting points did you use? A beam right through the door apertures under the roof (and blocked up to lift on the cant rails) looks favorite?
Cheers,
Greg
Old 11th December 2013, 22:45
EddyP EddyP is offline
Hi Greg,
I've done it both ways, first was with four blokes, then during the build I wanted it up again so used my hoist as I was on my own.
If you do decide to use a hoist then you need to make up some bits of wood for the strap to put the load onto, because at the top of the door apertures is the edge for the door seal, you'll break this if you don't spread the load. (talking from experience)
Is your body painted yet?
copyright madabout-kitcars.com 2000-2018
