Old 7th April 2014, 09:46
blooka blooka is offline
blooka is on a distinguished road
Smile Which radiator?
Hi All
Is it possible to fit the original radiator to my Sammio from my herald 13/60 into the same position so that I dont have to add an expansion tank, and without it fouling the bonnet?
If not whats do you think is the best option
Cheers Dave
Old 7th April 2014, 10:15
AndyP57's Avatar
AndyP57 AndyP57 is offline
Hi Dave,
In practice, we've always had to lower the radiator, even when using the Navigator bonnet. On our latest car we made a simple steel bracket to hold it in place bolting into existing holes in the chassis. I'll take some photos as soon as I get a chance if it will help.
Old 7th April 2014, 11:28
cheers Andy that would be much appreciated
Old 7th April 2014, 12:12
AndyP57's Avatar
Hi Dave,
A couple of early photos of 274 radiator fit.
Now tidied up a bit but essentially the same. There's a steel 'joggled' bracket holding on to the bottom using existing holes and I cobbled up a steel rod restraint for the top using parts of the donor's bonnet hinge mechanism. It has a bolt into the top fixing of the radiator and a double nut above and below the existing bracket slot at the chassis end.
Not that the radiator does slope (oops!) forward and has an electric fan with a thermostat in the top hose.
I hope that helps.
Old 7th April 2014, 13:45
thanks for that andy, thats probably the way i`ll go.
does it have a header tank on it or will it be fine without one ?
many thanx again Dave
Old 7th April 2014, 14:02
AndyP57's Avatar
On this car we mounted a renault Clio header and are currently looking for a good alternative. If we get enough demand we may be able to commission a small tank with correct connections for the existing heater hoses and a pressure cap.
Another alternative is to go the way Mr Towed has, in having an in line filler on an extended top hose running towards the bulkhead 'shelf'.
Old 7th April 2014, 15:38
Not sure if you can clearly see how I set mine up in this picture -
As Andy says, I've just got a filler neck in line in the top hose from the 'stat housing, which then returns through 180 degrees almost immediately to run back to the radiator top connection.
If I did another I'd probably use the very elegant solution adopted by Phil J on his builds -
Not the best angle to see what he's done, but the header tank is the small alloy pot immediately behind and just on the far side of the rocker cover. Nice.
Old 7th April 2014, 16:43
Here we go, found a better pictures of mine, but I have to say I actually prefer Phil J's set up -
Old 8th April 2014, 19:42
swifty's Avatar
swifty swifty is offline
Apologies for hijacking your post Blooka......Mister Towed the first picture has an alloy rad while the second has what looks to be a standard rad was there a problem fitting the alloy rad?
Old 8th April 2014, 20:48
Swifty - I can answer that one for you...
Post #7
- First photo is of Mr T's alloy radiator
- Second photo is of a different car (Phil's) with a different radiator & an nice expansion tank.
I think the only problem Mr T had with the alloy radiator was when he accidently knocked a hole in it and had to buy another one.
Old 8th April 2014, 21:20
I think the 13/60 rad is a bit smaller than the Vitesse ones, but one thing to be wary of that i had with mine is that originally i lowered it too much and seeing as it's quite exposed under the front it was "squeaky bum time" a few times until i tinkered with it
Old 10th April 2014, 20:34
Patton's Avatar
Patton Patton is offline
It could prove easier to say than find one, the MG Midget 1500 has a filler point on top of the thermostate housing and a standard exspansion tank by the radiator cap. PAT
Old 10th April 2014, 21:18
thanks for all the info guys I`m slowly getting there with your input
Old 11th April 2014, 19:48
phil9 phil9 is offline
i use a rs 2000 ford rad works great
Old 12th April 2014, 11:40
I'd probably go old-skool with a copper cored radiator if I built another rather than modern alloy. Can't remember which thread it was on but I believe someone far more qualified than I raised a very good point about the thermal conduction qualities of copper being far superior to aluminium in transferring heat from water to air.
My shiny alloy Honda Civic Type R racing rad might look cool (pun fully intended) but it definitely isn't as efficient as Phil's Ford RS 2000 jobby time-warped in from the 70's.
Old 12th April 2014, 12:26
the ford rs 2000 rad is copper ,had it made at boston rads it has 64 copper tubes [std 48]looks a bit ruff as paint has come off.. it works very well and just fits nice under bonnet they can make them
as wide as you like the chap said they used them to cool v8s when a small rad is needed...the pipes to the pot also holds a bit more water as well ..works for me ...
Old 13th April 2014, 10:11
Viatron Viatron is offline
Have been thinking about the rad whilst dealing with the nightmare that is my engine ECU. I too have the Type R Ali Rad but I'm just not sure it will look right so have pretty much decided to give it a dusting of satin black just to make it look a bit more retro.
TTFN
Mac
Old 17th April 2014, 08:13
Were your radiators from this seller and do you get a better price dealing direct Phil?
http://www.ebay.co.uk/itm/RADIATOR-T...item3ccfce1a44
