Old 19th October 2014, 13:32
Patton's Avatar
Patton Patton is offline
Default Pats Z300 build
Right hopefully I've cracked the picture posting.
I'll start with a piccy of the base car, it's a 1.9 narrow body for £1100 including travel to Swansea and driving back selling off the bonnet and other bits the total came to £970. I've got to get this picture thang cracked
Old 19th October 2014, 16:42
redratbike's Avatar
Click the postcard and paste in the URL of your image
Old 19th October 2014, 17:21
Patton's Avatar
Thanks redratbike for the hint so here goes.
[/IMG]
I think I've cracked it, when purchased one of the faults was a fuse blowing removed the sleeve and bingo then a new MOT straight thru now I take it apart no disc cutter required
[/IMG]
[/IMG]
now lets see!
Old 19th October 2014, 17:23
Patton's Avatar
I seem to have cocked up agian with my pics a little box with a red X in it.........
Old 19th October 2014, 17:59
Did you ever paint your Spyder Pat?
Old 19th October 2014, 18:58
y cymro's Avatar
y cymro y cymro is offline
Assuming the photos you want are already shown on another website, right click over the image and 'copy' the URL then create your message here and type '[IMG]' then paste the URL and after it type '[/IMG]'.
You should be able to edit your earlier effort to make sure it's in this format.
Good luck
Old 19th October 2014, 19:16
Patton - It looks like you have a lot of stuff before the actual image location which is causing your problem. The bit you need is just - http://i1127.photobucket.com/albums/...esized/Z34.jpg
If you use Chrome as your browser you can simply right-click on the picture and select "Copy Image URL" you then put [ img] but without the space, paste in the URL (CTRL-V) and then [/ img] again without the space
Old 19th October 2014, 20:17
Patton's Avatar
thanks guys, Chris is going to stick some more on here and the Z3 is a lovely drive but that compares to the spyder and a jago geep. The spyder is going to be painted for early next year slowly coming back together........
Old 19th October 2014, 20:27
IanA's Avatar
IanA IanA is offline
Yay- another one on the way- is yours #2 or #3 ???
Old 19th October 2014, 21:39
Patton's Avatar
Not sure of the number Ian Chris is the one to ask, been using her for a couple of weeks
Old 22nd October 2014, 13:57
Hutson Hutson is offline
Hutson is on a distinguished road
Default Color
Hi,
Are you intend to leave your car in silver? I'm thinking of a z300s In silver.
Do you have already some pictures?
Best regards
Old 22nd October 2014, 16:54
Patton's Avatar
Hi Hutson, yes the original BMW colour with 2 black stripes like a dodge viper, I've some pictures but as you can see from the begining of the thread I'm having trouble uploading them. It's not painted yet but I'm using it daily to find any niggles before the paint goes on early next year, regards PAT
Old 23rd October 2014, 10:43
Default Silver Z300S
Hi Pat, that will look great! I would like to change the mirrors (http://www.ebay.com/itm/4-CHROME-UNI...-/181499953281) and put on bolt on wire wheels. I am not sure about the rear lights, they must wear an E mark on the continent. I'll fallow your project as I am intend to start mine next year (retirement).
Regards, Walter
Old 23rd October 2014, 11:42
Patton's Avatar
Walter hi, I have a set of those mirrors but they are not very good as mirrors but look good on the car still trying to find the best place on the doors or forward on the wings, my rear lights are BMW from a 2002 with a red lamp in the drivers side clear lens as a fog lamp,I'll try and get some more pictures on later cheers Pat..
Old 23rd October 2014, 11:52
Pat - If you put your mirrors on the door then mount them further back than on mine. I have to use a small child's hand to fit the bolts inside the doors. Also the passengers side is purely cosmetic unless you want to look at the pavement behind you as you drive.
Old 23rd October 2014, 12:21
I would recomend to stay clear of them wing mirrors, i have them on my mx250 and cannot see a thing out of them!
Old 16th November 2014, 10:10
Patton's Avatar
The thrust bearing has just eaten it's way through the clutch bugger was making a noise should have done it sooner, got to be done as shes going to Chris n Dan for a remodelling on friday....
Old 16th November 2014, 10:32
Bad luck Pat, my clutch failed while I was paying for dyno time so I know how you feel.
Old 16th November 2014, 22:31
Good luck with the clutch Pat. Hope to still see you on Friday.
Old 20th November 2014, 10:13
Patton's Avatar
It started with a bit of a squeak, it's not just the thrust bearing it has destroyed the plate, cover, the duel mass flywheel (all the rivets rolled out the bell housing) and the thrust bearing housing tube on the gearbox, I'll still be at Chris 'n' Dans on Friday...
