30th October 2015, 19:10
Up-dating my McCoy
In the beginning
I first heard from a friend about the car, he told me that a friend of his was selling a mini based kit car but couldn’t give me any details of it, I arranged to go and view the car thinking it may be a Mini Midas or similar but when I first saw it, it reminded me of a car I was familiar with from the 70’s, the Clan Crusader but it didn’t look quite right and I knew the Clan had an Imp engine, looking around it had stick on letters saying McCoy which then I was not familiar with, I asked the price, he told me £200 and I gave him the money. It wasn’t running very well so I organised a trailer to get it home.
I got the trailer and went to collect the car to bring it home…
The next day I had a good look over the car and didn’t look too bad but had mechanical issues which I decided it was time for an overhaul, engine, gearbox rear sub-frame, the usual mini problems and later purchased a donor mini.
The interior was shabby but nothing that couldn’t be improved.
30th October 2015, 20:05
carry on, I'm enjoying this....
30th October 2015, 20:15
Stripping out
I had the car a few years before serious work was started, women’s requirements got in the way, you know what I mean, get married fix up house, move, fix up house etc etc….
Well I got the car on the 20th January 2004 so work out how much time I havn’t been able to get on with it.
Anyway, I was helping my eldest son put a Vtec Honda engine into his mini but he wasn’t putting enough effort into it due to him working 50 miles from home and it looked like I was going to do it for him, there he was wrong, I had other thoughts, I gave him a deal which let me have all the parts he had for the Vtec conversion which I could then put into the McCoy but I never made the deal until we had the engine running because a lot of work would be needed to get it to fit the McCoy and I wasn’t prepare to cut the car to get it to fit with knowing it was a runner.
In the mean time in slow time I started stripping out the McCoy to fit the parts from the donor mini just in case.
This had to come out….
and this along with several other parts that had seen better days…
The engine bay was stripped and cleaned…
On doing this showed a problem with the firewall suffering from heat off the mini exhaust, that would need repairing…
The door cards were removed along with the rest of the interior and the part have been stored until I get back to them.
The fuel tank would also need some work….
None of this would be needed as I would be fitting a beam axle with new swinging arm assemblies that my son had got new for the mini, but I would refurbish the swinging arms as spares…
This lot had to go… and it would become apparent that the front valance would need cutting to allow the Vtec exhaust to fit.
I am not sure what my son was thinking here but I think it would probably be ‘This will be a monster with my Vtec in’
30th October 2015, 20:41
The engine inspection
I said to my son ‘It would be a good idea to inspect the engine before we bench tested it’ because it was bought off E-Bay and collected from the back of a van somewhere in London and we didn’t have any history of it. All he knew that the engine was from a Honda Del Sol and it was a 1.6 B16A2 Vtec unit with gearbox.
We emptied the sump and with horror about a litre of water came out with the oil and sludge, so the sump was to be removed for further investigation
On removal of the sump the bottom end looked surprisingly clean but the sump itself was full of sludge.
The small amount of emulsified oil was removed….
The main and big end bearing shells and crank were inspected and only a small score was found on one of the shells..
So all was cleaned and rebuilt..
While the engine was out a new clutch assembly was fitted along with a new timing belt and tension pulley.
Reason: .
30th October 2015, 21:14
Sub-frame build
Reason: .
30th October 2015, 21:41
Engine bench test
Heath Robinson would have liked this, I pulled a bench out into the garden and clamped the sub-frame, complete with engine and mini fuel tank a radiator and wiring harness, stuffed an old silencer into the manifold with fire gum attached a battery and tried to fire it up…
Go here for first trial video https://www.flickr.com/photos/383774...7658176284393/
The problem was the immobiliser within the ecu, the steering column was from a different car than the ecu, so the internet was called for, I went searching for possible solutions and it came up trumps, a guy on a Honda forum described in depth on how to by-pass the immobiliser circuits in the ecu, this meant opening it up cutting a couple of resistors out and putting in a few links, after doing this, this is what happened next
Go here https://www.flickr.com/photos/383774...7658176284393/
Reason: .
30th October 2015, 21:45
Well that's the first 5 episodes of 27 to date, more to come, watch this space....
Reason: .
31st October 2015, 10:06
Engine bay mods
Well the deal was done and I had most of the parts to complete the job so I thought, time to make it fit.
The engine was removed from the sub-frame and then the engine bay was cut about to make it fit
I set up a pair of straps around a piece of 4x2 straddling the wings and the sub-frame and started to lift into position, cutting material from the car allowing it to raise into the correct position, this is how I envisaged the hole assembly would have to be installed. When putting it in the mini there was a removable flip front so no problems were there, I did at one stage consider flipping the front of the McCoy but changed my mind.
Finally after removing material from the inner wings and the front valance it was in..
The sub-frame was bolted at the top but the two lower mounts where sitting off the body, The area around the mounting plates on the car were cleaned back to the glass and pads were glassed into position, the sub-frame mounts were dressed in cling film, the sub-frame was re-fitted and the pads were shaped to fill the gap.
The sub-frame was forward of the front valance so some cutting was required there.
Now for the frame and the engine, the engine was refitted into the sub-frame and the whole assembly onto a trolley I had made earlier, the car was jacked and the lot was slid under.
Then the car was lowered and more bodywork cut away to allow passage…
Don’t fit…..
More cutting…, as you can imagine the car has been going up and down like a fiddlers elbow by this stage..
Do fit…phew..
Next was the issue with the exhaust manifold and front sub-frame cross mount plates, something had to be done with the front valance to tidy that up
More cutting in order then, gees this car was light before but at this rate there will not be much left…
That’s better now to put some strength back..
That’s better.
Reason: .
31st October 2015, 10:07
Engine bay mods (cont'd)
31st October 2015, 11:01
The Fuel Tank
On removal of the fuel tank it didn’t look too bad and there was no sound of rust rushing about inside, if I were to use it again it would have to either be run with an external or an internal fuel pump and as I like a challenge I decided for the latter, a pump from the same car the engine came from, I obtained a pump from a civic with the same engine and checked it out against the tank, depth was a perfect fit and the rest of it seemed to be too, the only problems I had now were where are the baffles in the tank and how do I remanufacture the opening for the pump to fit…
After browsing the net I fortunately came across these images, result…
Brilliant the pump will fit between the baffles and I know where to cut the hole…
Hmmm next was how to fit it, I could either cut a civic tank up and use the interface from there and weld it into the tank or I could do it the hard way and do it properly so I opted again for the latter…
First I had to design and make a tool to create the swaged edge for the gasket to seal against, so into work, knocked up a tool and then done this…
Get old tank…
Mark out and cut holes…
Trial fit pump..
Fit tool and tighten, loosen, turn, tighten, loosen turn etc …
Remove the tool and hey presto a nice swage…now for the fixings…
Clean interface in and out and clean fixings.
Silver solder fixings In one by one allowing to cool at each fixing.. (NOTE: Ensure the tank has been completely cleaned off any fuel vapours if you want to try this at home, I will take no responsibility if you blow yourself up)
All done and pump now fits.. now to make it clean and sealed inside and nice on the outside
Reason: .
31st October 2015, 11:02
Fuel tank (cont'd)
31st October 2015, 11:36
Excellent, thanks for putting all this effort into the thread a most pleasant surprise when I logged on. That swage tool is a work of art you should hire it out, I followed a McCoy last week they look better as they get older Ed
31st October 2015, 12:50
Hi Ed, I thought I should as I have been teasing for a while, I don't think you will reckonise mine when its finished, if you see that McCoy again would you mind taking its reg no as I am trying to make a database on them, cheers..
31st October 2015, 13:10
Rear end
Now for the back, the old sub-frame was in serviceable condition believe it or not but not for me, I wanted to use the beam axle my son had for his mini, the problem with these after market items they do no cater for everything and the beam was no different, it did not have provision for the handbrake cables so as its what I do I made that right…
Having that sorted the beam was drilled for fit and powder coated..
The beam was offered up and centralised, the car drilled and then bolted into place, I will be strengthening the heal plate it fits to later…
Nice new coil overs..
Refurbished swinging arms with new brake parts and bearings were then fitted to the beam, all the geometry will be set up at a later date..
I was going to have it sit on revolution 12” wheels…
But decided on these 13” Starmags..
The problem with all McCoy’s they sit high in the arch at the rear, even using hi-lo coil overs, I have thoughts on righting that later.
31st October 2015, 13:35
Rear Lights
Reason: .
31st October 2015, 13:46
The boot lid
Next was the boot lid, first thing was to flat back and fill the hole that some previous owner drilled for a hideous ill fitting spoiler, maybe he liked it but not my cup of tea, I have other plans on that front and I am considering integrating an air brake…hehe
A few coats of primer..
And a couple of top and that will do for the time being..
31st October 2015, 14:08
On show at the McLaren show in 2011
As my eldest boy works at McLaren, he got me an invite to their yearly show for employees, so onto a trailer, 50 miles up the road and then on show, It got quite a lot of attention as people thought it was a Clan Crusader but couldn’t work out why it had a engine in the front…
We had a good day talking about the car and putting people right about the car and also enjoyed walking around all the other cars owned by employees, we also had the privilege walking through the factory….I wish my garage was so spotless…
31st October 2015, 14:21
In it’s new home
During the long time working on this car my house extension including my new garage was build, the garage boasts carpets and central heating, power and light, now things can really get started and I would not have the weather, lack of light and the cold to stop me, but there is always the wife and a new kitchen and dining room had to be done before I could get on…
but after I had satisfied I was allowed to continue with my quest…
Engine out again….
And started on the engine bay harness..
Reason: .
31st October 2015, 14:43
Some future mod’s
I have along the way had a few ideas to modify the car and acquired parts to do them, here are a couple
A Honda Del Sol dash to be altered to fit,
A rear spoiler from a Mazda Rx-7 FD and a Subaru air intake
And a rather large turbo…..no seriously the car will be fast enough without that and anyway that’s what we fitted to my son’s Rx-7 which took the BHP to 423..
31st October 2015, 15:23
The exhaust
Reason: .
