Old 16th February 2018, 22:00
Nostromo Nostromo is offline
Default Paint inside the car body
Hi folks, apologies if this has been answered before (I've searched but not found any answers) but is there a particular paint I should use on the underside of my fiberglass kit? I've read that fiberglass is porous so I assume some sort of weatherproof or rubbery paint?
Old 16th February 2018, 23:55
DaveP DaveP is offline
Hi there,
A common approach I believe is to paint the underside with flow-coat. A hard gel-coat. It has many of the properties the underside needs.
I’m new to this game too but see a few people on here recommend/ use it.
Old 17th February 2018, 06:38
Jaguartvr's Avatar
Flowcoat is cheap and gives a good finish. It is the same as gel coat but you have to add a small amount of wax, this rises to the surface to form a skin (you can't see it), the skin allows the flowcoat to harden. If you want to add a second coat or paint it, give it a good wipe down with meths first to remove the wax.
You can have it mixed to a RAL colour to match your preferred colour. Makes it very easy to wash mud and road grime off and looks much neater.
Old 17th February 2018, 08:51
NeilF355 NeilF355 is offline
Hi
It was discussed here
http://www.madabout-kitcars.com/foru...ead.php?t=6594
Regards
Neil
Old 17th February 2018, 10:48
Great, thanks all. Flow coat it will be then.
