Old 27th May 2018, 12:06
Leadfoot's Avatar
Leadfoot Leadfoot is offline
Leadfoot is on a distinguished road
Default Nearside driveshaft
Having suffered a driveshaft failure coming back from Stoneleigh, I have now repaired the hole in the gearbox and fitted a new driveshaft. My issue is that the tri-bearing on the inner joint is very close to coming out. I can feel the bearing edge through the rubber boot. It will drive I'm sure but it's like the driveshaft is approx. 1.5" too short. I bought the standard nearside driveshaft that would have come from the donor car (1.6k Rover 400 Tourer). I've altered the suspension settings to try and get the angle down so that as it becomes straighter, the more it engages with the inner joint. I'm even thinking of making a new gearbox mount to pull the engine to a greater angle in order to straighten the driveshaft further. Seems a lot of work for a part that should just do its job...
Old 31st May 2018, 06:21
limpabit's Avatar
limpabit limpabit is offline
Never heard of driveshaft problems, with 1.6 K series models only T series.
Clutching at straws. Wonder if the drive shafts are different part numbers from the 400 and 200 series? Know there were changes like clutch system that were different.
I’ll try and have a look on Rimmer Bros after to compare part numbers. What year was your donor?
I know 420 related but driveshaft length problems
http://www.madabout-kitcars.com/foru...ght=Driveshaft
Old 31st May 2018, 11:41
Cees Bakker Cees Bakker is offline
Cees Bakker is on a distinguished road
Default driveshaft
isn't it a problem of old engine/gearbox mounts?
when you push hard, change the engine of position?
Old 31st May 2018, 12:39
limpabit's Avatar
Hmm a little confused.
Had a look on Rimmer Bros web site. 1.6K post 95. It's saying on came in an auto version only. 1.8 was manual.
Pre 95 was Honda.
Old 31st May 2018, 19:49
Leadfoot's Avatar
Default Driveshaft failure
So today, after patching the gearbox, resetting the geo, making new engine mounts and fitting the new driveshaft, I got 6ft out of the garage and the driveshaft popped out straight away. Arrg!
So I'm left with the following options; buy an off the shelf option (cheaper and preferable), have one custom made (expensive) or modify the existing one (dubious reliability).
The Rimmer Bros site doesn't supply dimensions and they're also expensive.
The replacement I bought is from a 1997 416 Tourer N/S which is the correct donor part.
My resolve is being drained...
Old 31st May 2018, 20:39
peterux's Avatar
peterux peterux is offline
Do the old ones have any part numbers stamped on them? It may help find the right replacement.
Also, I guess it's possible that you have been supplied the wrong part?
Old 31st May 2018, 21:18
Leadfoot's Avatar
Hi, can't see anything on the original but I did do a side to side comparison of old and new and the length was the same. That's why I couldn't understand today's immediate failure...
The 'original' one I assumed was just worn but in retrospect it was probably too short and that's why it failed as well. A bit stuck at the moment tbh as the part I ordered was as per the original donor.
Old 2nd June 2018, 21:30
limpabit's Avatar
Donít worry plenty of hurt feet kicking the car. Know how you feel.
Let me know year and model of 400. Iíll compare with 200.
Old 3rd June 2018, 09:15
Leadfoot's Avatar
Hi Limpabit, took the new driveshaft back out and stripped it down on the inner end to transfer this onto the old driveshaft, unfortunately the tri-bearings inner cage height is thicker and has a larger spline diameter than the old one. Thought I caught a break there for a minute but alas no...
I did a length comparison test again with the boots removed and found (as per Peterux's thoughts about the right part being supplied), that the new driveshaft when compressed fully, is 20mm shorter than the old one.
620 VS 640mm.
I did a lot of sanding of the old rusty and pitted CV joint and found a number I can't seem to trace. GKN HSP ?08703 088 CS5 EMA7 96 12 19A. I can't make out the ? (it could be a damage mark, A, P or an R).
The barshaft inner which the tri-bearing assembly slides onto and is secured with a circlip, is a 22 spline and approx. 24.2mm OD. Oddly enough, exactly the same as the input into the gearbox.
For reference, the new driveshaft from J&R Part No. Is DS266. I've e-mailed them about the DS178 to find out the difference.
Btw, as per an earlier thread, the donor model was a Rover 416 Tourer 1997.
Old 4th June 2018, 07:10
Phaeton Phaeton is offline
Phaeton is on a distinguished road
Do you know somebody else with the same kit, could they measure where their engine is mounted, very remote possibility is that your engine mounts have been mounted too far towards the drivers side?
Old 4th June 2018, 15:30
Leadfoot's Avatar
Hi, the pick up points for the engine and gearbox are set by the chassis builder so I have no reason to think it's set too far one way from another. There is 40mm worth of sliding play in the driveshafts, so if the drivers side was say, bang on centre, then anything more than 20mm would have it bump stopping on the gearbox end..? Wheels are central to the bodywork so don't understand why I'm having the short driveshaft issue. I've found a site that shows the driveshaft lengths and it does state that the standard item is 620mm long. So I've just ordered a cheap Rover 25 driveshaft off eBay as this is stated as being 645mm long. We'll see if it fits...
Thanks for responding.
Old 4th June 2018, 15:36
Is it a PG1 box?
Old 4th June 2018, 17:45
Leadfoot's Avatar
Is it a PG1 box?
No, it's the R65 I believe.
Old 5th June 2018, 07:22
Ah okay I have the PG1 in the MGF subframe was going to offer to try to measure but if it's the R65 then it's not going to help, unless that is the issue the mounting is for a PG1 box
Old 5th June 2018, 21:09
Leadfoot's Avatar
Thanks for the kind offer of support anyway. Much appreciated.
Don't know what the dimensional differences or mounting points are between the PG1 and R65. It was a thought that if my gearbox had been trashed, I would have considered a swap to a PG1 but mine seems Ok despite the hole it received.
Hopefully, the driveshaft that I've ordered will arrive and be the right length so I can fit it at the weekend . We'll see...
Old 8th June 2018, 21:59
bigrich's Avatar
bigrich bigrich is offline
Hi Leon,
I reckon the rover 200 or rover 25 shaft will work for you.
Mine is an R65 gearbox from a 1997 Rover 216, with a Rover 216 driveshaft..no problems with this popping...angle still looks tight but runs OK
Old 9th June 2018, 22:36
Leadfoot's Avatar
Originally Posted by bigrich View Post
Hi Leon,
The 645mm long Rover 25 nearside driveshaft fits fine and engages better than the brand new/old one (620mm) that was in. You called it in advance Rich
