Old 4th September 2018, 16:03
Default 'Modern' Z300s
Just juggling some ideas, and I'm wondering (and would value opinions) on the merits of putting a recent rear light cluster on a Z300S..... With that 'round rear end' it looks like several will fit eg a Vauxhall Astra or (more costly) latest Range Rover. I'd avoid LED ones due to complexity issues, and also I've observed most LEDs have 'angle of visibility' issues. Would a similar approach (ie more recent lights) be required at the front to get a cohesive style?
Old 4th September 2018, 16:54
Jaguartvr's Avatar
https://zroadster.org/threads/modifi...-relays.15927/
Modified LED flasher units for sale, the flashers are the only LED bulbs that cause problems
Old 4th September 2018, 22:04
Fancy rear lights have become a relatively cheap way of making cars look 'special'. Check out some of the 'budget brand' cars.
The Hyundai Shit Box 2* had some fancy integrated round ones with a star like effect. The challenge is that they are designed to sit flush with the body rather than surface mount. There are probably a few Mini options kicking around.
* Might not have been officially called the Shit Box, possibly Matiz?
Old 4th September 2018, 22:53
My intention wouldn't be to highlight (no pun intended) the lights, just to modernise the overall appearance (maybe think TVR? ooer). I really dislike (for instance) the use of DRL's in different shapes to 'add bragging rights' to more up-market models. In fact I dislike DRL's on principle as they just introduce more danger to the roads long-term (as ROSPA pointed out before DRLs were introduced, but their views were ignored). Maybe SB is what Matiz means in it's manufacturer's land?
Old 5th September 2018, 07:14
check out the bright blue Z300S that Nubodi did. That was a modern take on the car.
http://nubodiautos.moonfruit.com/diy-kits/4593423443
There are better pictures if you google a bit
Old 5th September 2018, 10:32
IanA's Avatar
IanA IanA is offline
... In fact I dislike DRL's on principle as they just introduce more danger to the roads long-term...
I only fitted them to my Jago to take the p!ss out of Mercedes drivers. (Does it work WCA?)
http://www.lightmare.org/
Last edited by IanA; 5th September 2018 at 10:35.. Reason: http://www.lightmare.org/
Old 5th September 2018, 10:36
Jaguartvr's Avatar
Whats a DLR?
Old 7th September 2018, 11:01
kon kon is offline
kon is on a distinguished road
DRL=Daytime Running Lights
https://en.wikipedia.org/wiki/Daytime_running_lamp
Old 22nd September 2018, 22:33
Check out the JoeB Z300s build thread . Modern combination with lighting, colour and wheels. Looks like a modern twist on the design to me.
