Old 10th May 2019, 21:25
Hughandjen Hughandjen is offline
Hughandjen is on a distinguished road
Default Remote and stop/start help
Hi guys
My donor Z3 came with only one key and that did not work the locks with the buttons. I took it to bits and it has been butchered with bits of foil glued in place. Itís obviously not going to work.
Question is do I go to bmw and get ripped off buying two keys with remotes or is there a cheaper aftermarket solution? I quite like the idea of a start button instead of ignition key too.
Any advice ?
Old 10th May 2019, 22:30
Nostromo Nostromo is offline
There are plenty of push start button kits around but the majority still require a key. I expect a full replacement will be fairly costly.
Your key could well have a transponder for an immobiliser integrated also, i'll admit to knowing nothing about the z3. Maybe you could look into a new alarm/immobiliser system . I remember the old clifford ones were modular and you could add or remove bits like intellistart, full closure etc. There may even be one which can replace your key all together. Just a thought.
Old 11th May 2019, 07:27
When I took the key to bits there is a transponder to immobilise the car so I will have to incorporate that in the solution.
Old 11th May 2019, 12:09
IanA's Avatar
IanA IanA is offline
Forum Search is your friend- try "keyless entry".
Old 11th May 2019, 12:44
Thanks Ian
Old 11th May 2019, 14:06
ericholm's Avatar
ericholm ericholm is offline
Cool
Hi Hugh,
I sent you a private message.
Thanks,
Old 11th May 2019, 21:48
Originally Posted by ericholm View Post
Hi Hugh,
Thanks,
Just replied
