Paint to match the coating on the chassis
12 Oct 2007, 12:34pm
I have cut off the plates that hold the striker pins for the doors (to fit the new ones that Marlin gave me) and so have a bit of the chassis now with no powder coating on it. Can anyone tell me what the best match is in a finish you can apply yourself (I guess it will be paint of some sort).
12 Oct 2007, 2:26pm
I've been using satin black spray on hammerite on the odd ding and scratch I've put on mine.
Widely available, cheap & you'd be hard pressed to see where the 'powder coat' finishes & the paint starts. On places where I think it needs more protection, I've applied some POR15 paint, and then over sprayed with the hammerite once it's dry (I've done this on my front struts)
I believe Pete has used hammerite as well. I think Patrick has been using some special satin chassis paint.
12 Oct 2007, 5:08pm
Yes, that's correct, I use Hammerite black satin. Cheapest place is Wilkinson's but they don't always have the satin. I've also used Plasticote for metal, but it's a bit soft and scratches easily. The Hammerite is more durable once its gone off. The only issue with Hammerite is that I sometimes get a chemical reaction that causes little bubbles. Still haven't figured out what causes it?
12 Oct 2007, 6:59pm
Ive been using the chassis roll bar paint from CBS - thats what went on the seatbelt bar - its also rust resistant (it says on the can!)
