It does not seem long ago that I started the 200 engine as a last test before removal
It likely around the middle of May after I finished the last paying job.
Well its running again we are short of a few bits minor things like cooling, clutch hydraulic oil, gearbox oil, exhaust and so on but it runs and the ECU is talking to the 5AS and the fuel pump so all was well for the test run.
The electrical wiring is 95% complete with the lights wiring on the clams to finish, if I had the clams that is. I have fed all the circuits via water proof connectors on the cables to the clams to enable easy removal if needed and these are fitted ready for the final connections to the bulbs.
If you are heading into the electrics I could on request put together a ' things to watch out for and check' list for you. There are some little things you need to know to stop you making the same mistakes as me. For instance on the Marlin loom there are two green fed fuses 7 & 8, 'Switch 12 volt' circuits, these feed, two 'in loom' common points, these common points feed the designated circuits.
Now all you have to do is connect TWO green wires to the ignition switched fed are you are cooking. That minor detail would have saved me 4 hours fault finding had it been identified in a 'how to do ' instruction.
The hazards are also a trick you need to know (see separate thread 'Spare Wire' ) I am still working on that....
A tick list of tested working circuits is also a helping hand when its all coming thick and fast at the beginning of testing.
I also have a better camera so the shots should improve if the new camera is any good, its never the operator it always the tools that are wrong....
The front is almost together
http://img.auctiva.com/imgdata/7/9/7/9/7/3/webimg/159913978_o.jpg
The correct Rover RAVE (thanks John) also helped with real colours and pin out connections from the donor, detail the Haynes fails to provide.
The 5AS well that's a pain if you don't understand the operation, with Technozen's detail, confirming most of my trawled detail and added other snippets I did not know or understand, I now have FOB based immobilisation, and will add hazards on immobilisation and hazards and interior lights when de-immobilised as well as FOB sensing and tamper based horn alarm and clam open switched if I choose to fit them.
5AS and fuse mounting board
http://img.auctiva.com/imgdata/7/9/7/9/7/3/webimg/159913835_o.jpg
All this has been installed ready for the upgraded 5AS and a re-alignment of the 5AS, ECU and FOBs now I have the system proved with the original set up..
Door? Lock arrangement
http://img.auctiva.com/imgdata/7/9/7/9/7/3/webimg/159914168_o.jpg
Ign and FOB sensing coil fitted
http://img.auctiva.com/imgdata/7/9/7/9/7/3/webimg/159914347_o.jpg
The body panels are the next big thing I need to organise and I am looking at some options here.
Went to see BigFella the other weekend awesome yellow Honda powered machine, almost together.
Would love to hear it roar...
We are getting there....
JohnC
