suspension again!
2 Sep 2008, 9:41am
could someone give some info on the top wishbones--currently rebuilding same and cant recall which way to mount them-does the more acute angled curve go to the back or front?which way up are they mounted?
2 Sep 2008, 10:26am
curvy bit to the front, so the hubs lean further back :) You should be able to tell from the taper as well.
Should look like this:
2 Sep 2008, 10:32am
suspension again
Thanks Patrick,just my luck,had curvy bit to rear-another go tonight...maybe if its taken off ,I should go for new top bushes at this stage.
2 Sep 2008, 10:39am
If you have them the wrong way round the steering does not auto centre and it becomes and SVA fail point (as I found out the hard way)
