Steering Wheel Diameter
26 Oct 2009, 6:27pm
For all you guys who have your cars on the road:
What size steering wheel have you tried/fitted/ended up with, and why?
Is there an optimum diameter?
What is the biggest you can be comfortable with?
I am building a Cabrio, and as there will be no power steering I am inclined to go as big as is sensibly possible.
Can a standard 370mm BMW wheel be used?
How did you all manage to remove the fixings securing the BMW steering column - it seems to have circular shamfered nuts?
regards
Mike
26 Oct 2009, 6:47pm
Can't comment on the BMW size but I've got at 13" dia on my sierria based cabrio and a little heavy at really low speeds but otherwise its fine.
27 Oct 2009, 8:36am
I am using an old 14" Momo wheel at the moment. I bought it off Ebay specially for the SVA as it has a padded centre. I would say it is a bit too big and puts a small bulge in the tonneau. Steering a little heavy at manouvering speeds but fine on the move. I intend to get a 13" wheel sometime....
I don't rememember the fixings for the column - it was 5 years ago when I dismantled the donor. I guess the nuts are anti-tamper? I would suggest a decent set of molegrips might be the answer.
27 Oct 2009, 8:44am
I think I dremeled some slots into mine, and then used a dirty big screwdriver.
That was after hacksawing the column off it's mounting plate in the Beemer cockpit:
