Fuel Regulator - Type R
14 Apr 2010, 12:48pm
What fuel regulator have builders used for their Type R engines?
I'm assuming that it's got to work with injection pressures (higher than carbs) and have a return (to take fuel back to the tank).
I already have a separate pressure guage, so don't need that built into the regulator.
Any help, especially make/model/supplier would be greatly appreciated.
Thanks in advance.
14 Apr 2010, 2:49pm
I'm using an FSE fuel pressure regulator, set (I think) to 47 psi (static - no manifold tapping).
Fuel system goes:
Rover tank pump (8mm pipe) -> swirl pot -> walbro 255 -> filter -> t-piece (with 8mm tapping to fuel rail) -> fse regulator -> swirl pot (6mm from reg to swirl) -> tank.
Fse reg is approx 300mm from fuel rail, to ensure the displayed pressure is as close as possible to that seen at the injectors. Some people I believe have placed the regulator and gauge near the fuel tank, which seems daft - it's best to regulate as close to the point of use as possible.
15 Apr 2010, 9:50am
Thanks - that's good info.
Did you getthe regulator from Marlin? I don't suppose you know the model number off hand?
Thanks again.
