newbie after registration help
13 Jun 2010, 9:59pm
hi chaps
i am looking at building a car. but my first question is about registration. what parts do you have to use to get an age related plate ? new plate (i guess is all new parts) ?
any help in this area would be great
cheers
mark
14 Jun 2010, 7:40am
Hi Mark,
if you look at http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_10014246 you will see that you need to keep two major components from the donor. Usually engine and gear-box suffice, but the more components the merrier.
Best route is to at least photocopy the donor's V5 before notifying Swansea that the car has been scrapped. The V5 should contain the engine number, which can be checked when you register the car. Also when you go through IVA the logbook can be used as evidence of the engine's age and the appropriate emissions test can be applied.
Take and keep plenty of build photos to provide more evidence that you dismantled the donor, and built the kit. - I had trouble convincing VOSA that I had done all the work myself.
Enjoy your build
Chris
15 Jun 2010, 6:48am
cheers chris, very helpful. i guess i am right then in thinking that for a new plate, everything has to be new, and fully documented with receipts. ???
is there a link somewhere that tells me all the bits and bobs they look at when going through the new iva . (is it as big a pain in the tail pipes as what i have been reading)
thanks again chris
15 Jun 2010, 7:06am
I used these to get through my IVA
http://www.completekitcar.co.uk/svatoiva.html
http://www.businesslink.gov.uk/Transport_Theme_files/124_IVA_M1_Inspection_Manual__Version_4_0510.pdf
http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/DG_4022486
As for a new registration, I believe you are allowed up to 1 major referbished component on the car and still qualify:
VOSA wrote:
Where all the parts of a vehicle are supplied new by the manufacturer. Subject to the provision of satisfactory receipts and a certificate of newness these vehicles will be registered under a current registration mark.
Kit cars which have been built using not more than one reconditioned component will also be registered under a current mark. This is subject to the provision of satisfactory evidence that the component has been reconditioned to an "as new" standard. An IVA, ESVA, SVA or MSVA test will be required.
Cheers,
Jason
15 Jun 2010, 8:05am
Here is a link to the formal document, though I must warn you VOSA's version control is a bit iffy sometimes. However this one seems fairly current!
I think that most of the builders on this site have managed to get their cars through IVA without too much difficulty. Mine failed first time round on the VIN plate, some wiring that needed sleeving, and some exposed sharp bolt heads and other items around the front suspension.
10 Sep 2010, 7:57am
Get an old q plater silly money on eBay and they are less strict with mot requirements then you could spend a fair amount on upgrades etc that's what I'm doing
