First time power up
20 Aug 2010, 12:32pm
Hi all
Im pretty close to connecting the battery and going through the necessary steps to inject some life into my kit.
I have a pretty good idea of the steps i need to take, and wanted to see if there are any additional hints and tips for making this milestone a sucessful one.
My steps are
1 - With no fuses in vehicle, no fuel, connect battery
2 - With multimeter check no short circuits.
3 - Fill engine with oil, coolant, check for no leaks (no fuel yet)
4 - connet power fuses, check ignition switch and powers on circuits (15,30, etc)
5 - check starter engages and engine turns over (wont fire no fuel yet)
6 - check coolant and oil levels and the engine pumps fluids around the system , top up as neccesary
7 - install one fuse at a time check cirucit for power in correct places, ensure fuel pumps engage,
8 - checkswitch circuits, eg indicators, headlights, hazards etc
9 - Disconnect return and supply to main tank (I dont want to use main tank as I dont have fuel sender yet, so top of tank is open)
10 - Turn engine over and see what happens.
Anything else??
Steve
20 Aug 2010, 4:06pm
Hi Steve,
Seems a very logical route...personally I just connected the battery up with all the fluids in and fuses and cranked her over....worked fine for me (apart from the fact when I took the key out she kept running!! - soon sorted that gremlin out)
My only advice would be to bleed the coolant system really well.....the bleed point and header tank are very close in vertical height and it is easy to get an airlock in the system.
...oh, and a must have (seriously) - bucket of water and fire extinguisher (just in case)
ATB
Rich
20 Aug 2010, 6:38pm
I just plugged in the ECU and hoped for the best.... brrrrummmmmm!
I did have a fire extinguisher, fire cloth, and hosepipe on hand to assist with any unwanted "entertainment".
21 Aug 2010, 9:12am
I tested the electrics as I wired them up, and deliberately left the fuel pump unconnected.
Then come the big day I filled up all the fluids, connected the fuel pump and turned on the ignition. I then checked the fuel lines for any leaks and when I was happy started the engine. On the second compression brrrrrmmmm!
I ran the engine for a few minutes, then checked over for leaks, and tightened a few hose unions.
21 Aug 2010, 9:46am
Pretty much the same as Chris here. As soon as the pumps had primed themselves and fuel had made it ways to the swirl pot and fuel rail, she caught pretty much straight away.
21 Aug 2010, 12:20pm
You worry to much Steve!
Connect battery up and and crank over without fuel. If there is a short, the fuse will blow. Check levels and add fuel.
Good luck. This is one of those defining moments. When it starts, you will have a big grin. If it don't start, do what I did. Kick the tyres then squirt some easy start in to make it start! Ran for a little while. Then went and found the fault. Had the satisfaction that I got it started even it the engine did not want to!
Good luck
23 Aug 2010, 7:01am
Do you want to know what happen????..............
I got the fire extinguisher ready to hand......
Hosepipe ready ready to hand.
Put battery in no poprblem there
Put fuses in, checked my circuits, nothing wrong there.
Turned the key and nothing happened..... I could here the starter motor go, so add a jump pack to the battery and the engine turned over.
Added some fuel to the swirl pot, having disconnected the main tank supply and return.
Turned the key nothing happened.
Check fuel pump voltage nothing, I had used a wire from the ECU that I thought was the for the fuel pump relay, it wasnt as it was only giving 3.6V.
So i moved the fuel realy over to the switched ignigtion, second stage on the ingition key.
I could here the fuel pump spinning up and making a whining noise until the fuse popped.
Checked my wiring again all was ok.
Checked against elsa win and I had the in and out fuel lines on the engine the wrong way round, pressure was building up behind the fuel regulator.
I had to remove the fuel lines and swap them over.
Did that and as it was under pressure had a nice huge plume of fuel vapor mist all over the rear end of the car, over my hands and face...nice.
No explosion, as no smoke in mouth at the time so was ok :)
Reconnected fuel lines, and went to turn the key again.
and Voila the engine fired up and idled. Fly by wire throttle also worked,
Had a problem with brake warning lamp, being on when it should of been off, and vica versa. Have the same with the oil pressure light, it off to start then comes on, So I have to fit a normally closed relay to invert this voltage.
As the day went on, i let the coolant get hot, and my rad fan kicked in!!
Bloody good feeling when the thing firsts fires up!!!!
So i made a video and put it on my website :)
First time fire up
Its streaming so you dont have to download it:)
Next step for me is I need speedo tacho etc. And connect indicators, brake lights headlights etc.
Module 3 might come october when funds and holiday allow
Cheers Steve
23 Aug 2010, 8:40am
Ummmm. Petrol mist... :)
Brilliant feeling, isn't it! Well done! :D
I noticed that your prop-shafts where turning when it was idling - did you have it in gear?
23 Aug 2010, 12:13pm
Nice action!
The first time the car fires up (that's the engine runs, rather than a 999 call), is just great... from this point it gets better and better I reckon - engine runs, car moves under own steam, car drives to IVA, registered, first road drive, and finally first track day......
23 Aug 2010, 1:04pm
Nope, but there is no force on the wheels, I can stop it with my hands.
If I grab it with my hands and flick it backwards it stops.
I have a brand new clutch in, but no clutch fluid at all yet, I dont have brakelines, so cant fill up the triple fluid resovouir.
My motorbike used to do this when it was on the center stand with the engine running.
If the car had wheels on, and was on the ground, i dont think it would drive off without me,
Is it a problem?
23 Aug 2010, 1:08pm
alackofspeed wrote:
Nice action!
Yup such a good feeling.
Until it fires up and runs, it an expensive lump of "scrap" metal, now its come alive its worth a bit more.
You make it sound like I have only just started..... so many more good milestones to reach.
Quite chuffed as well as it is all VAG gear not honda or rover where there is a bit more information from other builders available.
Had my ECU sent away for re-chip and imoboliser disabled. So far it looks like that was a good fix.
Also chuffed as I had to make and design the entire wiring loom from scratch.
Now I just have to hook up some lights and see if the rest of the loom works as its supposed to.
I think i might be looking at a spring 2011 IVA. :D
Steve
23 Aug 2010, 2:09pm
Is it a problem?
Probably not - it may be the vibrations making the the shafts rotate slowly - like you said, If it where on the ground with some wheels on it, you wouldn't have noticed it.
23 Aug 2010, 5:18pm
It's just drag in the gearbox, and totally normal.
23 Aug 2010, 7:26pm
To whom was the ECU sent out of interest, and what was the cost? Did they also bin the emissions stuff that is surplus on the Marlin?
Who supplied the exhuast? 1 cat, and 2 absorbtion silencers? I guess the turbo is doing a fair chunk of the attenuation.
I just spotted the boost pipework! That's a heck of a long run!
24 Aug 2010, 5:16am
Well done Steve. Sounds good!
Don't worry about the driveshafts. That's normal.
It is a good feeling for first time start up. Had it twice now!
Next is moving under it's own steam without the body on.:biggrin1: Won't be long!
Got a question for you. How easy could you make up another loom and at what cost? Pm me if you want.
24 Aug 2010, 6:51am
Dont know Mark@ Marlin arragned this.
Marlin, yep 1 cat, 2 silencers, post cat lamda probe is ditched
Yup front to back but the intercooler is at the front in the main airflow.
I appreicate lag might be a problem, but I hope I get an addtional performance gain with the location of the intercooler.
24 Aug 2010, 6:53am
Thanks !
Easy just takes about 6hrs labour and a load of wire.
Pm sent
27 Aug 2010, 9:12am
My engine is running realy rough when i give it a few revs.
I checked the spark plugs and all four were badly corroded.
The coill packs are supposed to have an o-ring seal to prevent water getting to the top of the plugs. They were all missing on my engine. This allowed rain water to get in, probably when the engine was taken out of the donor.
Some plugs had corrosion (brown water marks) about 10mm or so up the plug ceramic!!!!!.
Im surprised it actually started at all in that state.
So have ordeded new o-rings and new plugs.
Hopefully this should sort out my mis fire, and I should end up with a purring engine, fingers crossed.
I should be getting the new parts today, over the bank holiday weekend, i can then hopefully sort this out.
Might make a new video if it fixes the problems. :D
27 Aug 2010, 5:29pm
Press fit, or bolt down coils? The former in their earlier codes are unreliable, and if upping the boost it's probably prudent to replace them.
27 Aug 2010, 7:07pm
Bolt down ones. Two M6? bolts diagonally opposed
Ive done the plugs at 0.8mm
removed each coil one by one and there is a noteable difference (proper misfire)
as I remove each one. So i don't think it is the coils
I'm wondering if it gets starved of fuel at high RPM, as Im only using the swirl pot It may pick up "air" as the swirl pot isn't being topped up from the main tank.
Will need to get a fuel gauge in the main tank, then run it all from that, and see if the problem goes away.
It runs sweet at idle, so I think that is the cause
Steve
27 Aug 2010, 11:19pm
The bolt down items are normally very tough, and don't give bother - you're probably right to look elsewhere.
31 Aug 2010, 7:43am
Problem sorted !!!
My engine now runs smooth and screams its way to full revs, and boy is this thing AWESOME.
Im not too sure of the exact problem, but I did find a few interesting things.
The MAF on the air box, when wiggled, changed the engine note, on inspection the power connector blades were over strecthed, causing an intermitent connection, pushed them back together to ensure good connection.
Also on the MAF the insulation had worn out where it passes through the rear bulkhead, My grommits are not 100% completed.
The ECU hadn't gone through its "learning" phase.
In order to do this (Acoording to ElsaWin) the ignition must be on, but the engine not running, leave it for 5 minutes. For the ECU to do its tests.
Then when started the coolant temp must reach 80C.
So i left it idling for 5/10 minutes until my rad fan kicked in when set to 80C.
Then the revs much reach 3500rpm.
Applied the throttle, and now the mid range misfire, didnt happen.
Slowly increased the revs and "WAAAAAAAAAAAAAAAHHHHHH"
the engine is screaming.
Blipping the throttle down to full revs, the engine picks up instantly, and runs down when accelerator is lifted. With a few nice exhaust pops and gurgles as the engine revs decrease.
Got told off by the wife though, as the exhaust note caused everything in the house to shake. Dont piss off the neighbours!!! I do live in a quiet cul-de-sac so I could see her point. :)
I also set about bringing up some more electrical circuits, indicators and hazards are all working, side lights work, switch backlighing, and washer pump works (no fluid, i dont have a windscreen yet). Woohooo!!!
1 Sep 2010, 6:04am
Great stuff Steve! Going great guns!
What colour are you having the body?
1 Sep 2010, 8:32am
Cheers !!!
I havn't ordered it yet, but my current line of thinking is orange.
Then one day get it resprayed in some "Burnt orange pearlescent" type paint. I do like that colour ;)
Ive also ordered my instruments,
going ETB electrical gauges, white dial, red needles.
Speedo, tacho, water and fuel
Should be here in a week.
1 Sep 2010, 12:22pm
how big are your plums...?
150mph or 220mph gauge!?
