Axle Stands & 'Modern Motors'
23 Nov 2010, 3:43pm
Right. I need to do some work on Kitty the Jag (Replace front wishbone bushes - £150 if I do it, £900 if Jaguar do it :icon_eek: )
The work requires dismantling the suspension, so I need the wheels off - So ramps are a no go. Which means axle / jack stands are the only option.
The problem is placing them correctly - not an issue on the Gooster, as it has chassis / frame rails. The Jag, on the other hand, is a monocoque like most modern cars.
I can place stands at the jacking points, but I don't want to damage the underside of the car or any pinch / spot welds under there. Any suggestions? I've seen some people use ice hockey pucks attached to the axle stands with a grove cut in them to accomodate the weld seams, but I'd like some other options / opinions before I hoist nearly two tons of Coventry's finest up in the air...
How have you supported a car without front wheels in the past? Over the top, unsafe and / or Redneck solutions need not apply. :)
23 Nov 2010, 7:14pm
car Tyre cut and glued to the stands
24 Nov 2010, 7:44am
Dont know about Jags , but all Mondeos, Pumas, Fiestas and Escort Ive worked on usually have a relatively flat bit of heavy duty box section like monocoque near the front wishbones. I use plain old axle stands with a bit of pine about 25mm thick. The pine crushes nicely.
