number plate holder
22 Mar 2011, 10:37am
Has anyone got pictures of the marlin front number plate holder fitted,but with the nose cone off?
22 Mar 2011, 11:59am
Hi Jeremy,
this is the only one I can find and not a very good one.
Stripping down for painting by marlinpeter, on Flickr
I had to trim it to make it fit as my horns and rad bracket were in the way.
22 Mar 2011, 11:54pm
front valence
thanks for that..aside from the clamps over the bumpers,did you fix it to the cross member below the horns?Was it on for IVA? ta
23 Mar 2011, 8:25am
Hi Jeremy
Mine needed trimming as well. I just used 2 jubilee clamps to secure it round the bumper bars and it seems pretty secure. Only fitted it after IVA.
Tim
23 Mar 2011, 8:54am
I didin't bother with the Marlin holder. I've always thought it looked a little out of place on what is such a retro front end.
I made a couple of brackets myself, and attached it to the nose cone with a couple of stainelss coach bolts.
All they are is a bit of flat bar bent at an apropriate angle with holes drilled to accept the NP bolts and the fixings to the nose cone.
23 Mar 2011, 7:38pm
I fitted mine after the SVA test as I wasn't sure about the 'sharp' edges but I did put some clip-on edging along the bottom edge of the nose cone.
It's just fixed with exhaust type 'u' clamps over the bumper struts. I originally used some hose clips but I wasn't sure if they were strong enough. I think it should be fixed to the cross member to stop it flexing too much, but mine isn't.
I can always pretend i'ts like an F1 front wing that changes angle with the speed of the car :lol: :lol: :lol:
23 Mar 2011, 9:56pm
Number plate
Assuming a fail at iva is the most likely scenario first time around, I think I will go through with it on but well trimmed and see what happens.
27 Apr 2011, 7:45am
I haven't got the Marlin one either - I've used 2 flat strips and riveted them to the inside of the bumper bars and then bent them to follw behind the bumpers - can't quite remember how I attached them to the number plate but I think its a bolt at each end hidden behind the bumpers...
27 Apr 2011, 10:16pm
same two bent metal strips glued to the inside of the nose cone does the job for me :)
