Hi all
Nearly at the endof the build, just doing the last few jobs.
How have you attached the fiber glass windscreen surround?
Glued it or self tapped it?
If you have self tapped it ...........
1 ) does it prevent water coming off and over the screen getting onto your head in a down pour? Or in a down pour do you just live upto the fact your going to get wet!!
2) What type of / size of screw did you use.
I could see if I bonded it, that should the windscreen need replacing, the trim might end up being a sacrificial component in the process.
I wouldn't worry about water ingress from above the screen..... there are bigger holes it'll find its way through! On the subject of water ingress, whatever you do, make sure you position the screws such that they don't compromise the fit of the hood, and also that when you screw the trim down any hood clips don't press against the glass.
As said above really. Make sure you have enough gap for the hood. Don't let any metal touch the windscreen. I had one of the self tappers just touch, not screw into, the windscreen. Created a nice cracked windscreen.
