Got the Hump
8 Feb 2013, 5:04pm
:fencing: :fencing: :fencing: Kept looking at my seat position then the hump. I have taken a cast of the original hump. Make sure you put something on the original so it is easy to release! Out came the cutting disc and off it came now i can reposition and can also weld in some steel box to protect in case it rolls over(not that i intend to)
no working on car tomorrow defending my title in a f:fencing: comp
8 Feb 2013, 5:53pm
So you could say "you put the hump to the sword"
8 Feb 2013, 7:54pm
[IMG][/IMG] new position for hump
8 Feb 2013, 7:56pm
[IMG][/IMG] for me its too far off
8 Feb 2013, 7:58pm
8 Feb 2013, 7:59pm
8 Feb 2013, 8:02pm
may build it taller or add another[IMG][/IMG]
8 Feb 2013, 9:01pm
Nice work, I have to agree that the offset humps always bugged me, now the humps come separate at least ill be able to position them as I want.
8 Feb 2013, 10:05pm
Nice work, Noob. You are doing what I plan to do so I will be grateful for all pics and commentary. Do I see that you have marked a boot, and is that a ridge around the front of the cockpit?
8 Feb 2013, 10:15pm
yes i decided to set back the the dash for rev counter and cut out then bent some 4mm bar to join over the top and welded to keep frame intact[IMG][/IMG]
8 Feb 2013, 10:20pm
still work in progress if i started again iwould have altered the frame to make plenty of room for all the dials :frusty: [IMG][/IMG]
12 Feb 2013, 7:28pm
Your car is going to have some nice individual touches. :cool:
14 Feb 2013, 6:39pm
[IMG][/IMG]Going to make the hump a bit higher and added some protection for my head just in case. Hit with lump :smash: hammer seems strong enough
14 Feb 2013, 6:53pm
What about the other hump!
14 Feb 2013, 8:47pm
plan to have the other one removeable with a push on and lock system. not worked out how yet:juggle:
3 May 2013, 6:36pm
progress on the removeable hump[IMG][/IMG]
3 May 2013, 6:38pm
4 May 2013, 5:49am
Your second hump seems to be coming together nicely. :cool:
How did you get the hump's edges to match the contours of the body shell, was it just trial & error?
Also do you have any more details on how your boot / boot lid works?
5 May 2013, 11:21am
I made a cast of the other hump [IMG][/IMG] [IMG][/IMG] Then made a copy trimed to fit other side and marked the body. used poly vinal tape to stop resin sticking to the body and fibre glassed the outline i had marked out. placed hump over outline after triming. Used a level and wedges to match other hump and roughly filled to bond to the base. Finally glass fill and sand. The boot is still work in progress will need hinges that lift enough to clear curve in the body.
5 May 2013, 3:42pm
Thanks for the explanation.
6 May 2013, 8:46pm
Impressive! :biggrin:
