ABS sensor light on :-(
2 Jul 2013, 4:34pm
My abs light has come on my mk2 MX5 .
After a quick check it was found to be the front left sensor that is at fault.
I have searched all over the net and they are over £200 each!!!
Can anyone prove me wrong? Are there used ones available???
2 Jul 2013, 5:32pm
Mx5parts will probably be best on price. Dunno about your model but some abs sensors can't be removed without being damaged, if this is the case you might be able to pick up a complete hub second hand.
Best of luck!
2 Jul 2013, 5:54pm
Best of luck!
You're probably right...
2 Jul 2013, 8:11pm
depending on the connector, some of the 323 Mazda ones are the same... and much, much cheaper
2 Jul 2013, 10:02pm
Hi, give the guys at mx5 Heaven a shout, i just had them replace front+ rear upper and lower suspension and both front hubs with ancillaries with good/recon 2nd hand parts . Good prices, great service all round. I am not affiliated with them in any way, just had positive experience.
2 Jul 2013, 11:17pm
Just ordered a sensor and hub from mx5 mania.
£50 delivered. Seems like a bargain :-)
