my car is based on the e39 5 series rear axle sub-frame assembly, with e 36 front struts and i plan on fitting the s50b32 3.2 evo engine, which i believe i will be amount a hand full of people to have used this engine!
currently i have have the majority of the front suspension fitted, the rear subframe, pedal box and fuel tank fitted. i started playing around with the doors today as i am currently waiting on other parts and i cant seem to make things fit too well so i was hoping to get some advice before i go cutting panels and making mistakes!
basically i have followed the marlin manual and used 3mm plywood as a spacer on the bottom sill of the door, but it is the drivers side A panel louvred cover that does not line up so well.
the passenger side seems ok :
the top gap between the door and the lower edge of the A panel cover is fairly consistant and i can trim the panel to achieve a parallel gap of around 3mm either side.
however on the drivers side its a different story
as you can see the front corner of the door fits ok, but the gap gets progessivley bigger the further back towards the door you go:
however i am able to pull the scuttle down by hand to achieve the gap:
http://s223.photobucket.com/user/mcramsay3003/media/null_zps6fb95d56.jpg.html?sort=3&o=7
its almost like the rail the scuttle sits on is slightly twisted.
i can also achieve the correct gap by tilting the door up at the striker pin end, however this then leaves a massive gap between the bottom of the door and chassis sill :
all the hinges are welded onto the doors, and the chassis has the holes drilled already to accept the hinges, although the holes do allow a lot of ajustment.
i tried adding a few washers under the front scuttle securing nut to effectivley push the back of the scuttle down further which brought the gaps much more even, but then left a big gap on the front scuttle to the bulk head!
does any one have any advice onthis?
