sva noisy exaust
10 Feb 2015, 8:22pm
Hi my exaust on robin hood seems very noisy for sva test,is there anything i can do to make it quieter. Cheers Dave
10 Feb 2015, 10:15pm
When we were road rallying in the 70's and 80's we used to push Brillo pads up the back pipe and drop a split pin through two pre drilled holes. Once clear of the noise check we would pull the split pin and let nature take it's course...
Perhaps that wouldn't fool an IVA inspector, but it might give you a clue...
10 Feb 2015, 10:47pm
Dave1954 wrote:
Hi my exhaust on robin hood seems very noisy for sva test,is there anything i can do to make it quieter. Cheers Dave
Hi Dave,
you can get things called 'decibel reducers' that fit in the exhaust tail pipes. I've not used them so don't know how well they work? :noidea:
But you could talk to Jetex technical department....
https://jetex.co.uk/jetexstore/index.php?_a=category&cat_id=107
Alternatively Jetex do a big range of silencers so maybe fit and extra one or two?
....peter
11 Feb 2015, 2:06am
If you phone the SVA center or a track, you can get it tested for free. Well know definatley track if concerned.
I use the Jetex silencers for track days as won't pass some of the track day noise regs. Made them so they can easerly clip on. But not sure if iva guy would want to see a more permanent solution.
Long term, I'm going to get the silencer fixed.
11 Feb 2015, 9:04am
Merlin Motorsport based at Castle Combe sell products to get through noise tests. Castle Combe circuit is stringent on noise so as not to upset residents nearby. [url]www.merlinmotorsport.co.uk/[/url]
EDHave used the Brillo pad trick myself when I was Road Rallying in my younger days. What a smell they made burning out and then filling the air with glowing fragments of wire.
11 Feb 2015, 9:25am
:icon_biggrin: :icon_biggrin: :icon_biggrin:
6 Apr 2015, 10:48pm
Tack a washer down inside the exhaust, will reduce the noise, knock it out when test finished.
