Sportster Build Hampshire
26 Jun 2015, 3:40pm
hi
Just introducing myself as I am about to start on an E39 Based Sportster build. It is an idea that has been on the back burner for a while but has suddenly kicked off. Sort of now or never, time to put my money where my mouth is. So I now have a donor car on my drive and an order form in with Marlin.
Sure I will have plenty of questions and thank you in advance for your answers.
My first one might seem a bit of a leap but what are current recommendations on brake servos. I know there were concerns on Metro unit supplied by Marlin and there is a thread from a couple of years ago on a U.S. unit. What are people currently doing?
26 Jun 2015, 4:36pm
I'd highly recommend one of the US sourced dual diaphragm servos. I don't know if Mike is still doing his kits - a bunch of us did a group buy after we found them online... Mike kindly handled all the shipping and distribution, as well as getting adaptors laser cut.
26 Jun 2015, 8:24pm
Hi Chris, welcome!
The dual diaphragm brake servo is vastly better than the metro servo. Pedal feel and power gives you much more confidence.
26 Jun 2015, 8:31pm
The Metro servo is pretty useless. The boost ratio is nothing like the original BMW one and as a consequence you will find it difficult to stop as quickly as most modern cars - unless you are built like the hulk. I would consider the upgrade to the dual diaphram servo almost essential.
I have a couple of new old stock Metro servos as testiment!
Cheers Robin
26 Jun 2015, 9:08pm
Hi Chris
I would say using a Metro servo is bordering on dangerous - particularly if you fit disc brakes at the rear: they require more pressure to make them work effectively, which the Metro servo set up is incapable of generating.
A quip by Patrick about driving his Sportster with a Metro servo has stayed with me throughout - "Trying to brake hard behind a modern tin-top with a servo bigger than its engine can be scary!" - summed it up perfectly!
I do not have any dual servos left, but they are easy enough to order from US - but be aware you will have to pay import duty (5%) and VAT (20%) on the total purchase price.
I have some surplus adaptor plates if you go down this route - and can give you the part numbers of the Dual Servo and appropriate Sierra Brake Master Cylinder - if you are interested, ping me a PM.
Mike
15 Jul 2015, 7:56pm
Another e39 builder!! There are a few things you might run into issues with! I am currently the furthest ahead with the e39 build to date! ( last time I checked in I was beating marlin!!) give me a pm and maybe we could have a chat and I can point out potential problems/ some build advice!
