Hi guys
Since my bonnet has been refitted I've noticed that the front corner now sits higher than it should. The rest fits fine along the front. Is it possible to heat up the bonnet from the inside then put a weight on the corner to persuade it to go down?
I hope so.
I will have to be careful about my new paint job!
Has anybody tried anything similar ?
Well... I added some heat, not a lot, from the inside. She is now sitting in the garage with about 7 kg of weight resting on the offending corner. Will leave it over night and take a look tomorrow when I get back from work. I really hope it works
The chequered flag in Chiswick used to have problems with the TVR boot lids sitting too high.
They used to leave them in the spray oven overnight with a couple of old batteries sitting on them at a low heat.
Used to do the trick but they always used to go back to the original shape.
The just kept on doing it until the customer gave up and stopped coming back.
slit the bottom of the lid, warp into correct shape and add a layer or two of fiberglass to the inside. That should keep it in place.
I did that ages ago before it went to paint (the first time)
I'm a bit reluctant because I don't wish to damage the paint, but if it does not work then I may try it again.
