Just starting my 250 build. Base car is a tatty 2.8 Z3
Going to dye the carpets and fit Rover 75 seats
It will be a long build as don’t have much spare time
Usual Z3 problem. The sponge Under the carpets was wringing wet and carpets were stained and a nasty beige colour. I decided to take them out, power wash them and then try and dye them black. Really pleased with the results.
Hi guys
I’m putting Rover 75 seats in the car and have just losely placed them in, but they are very snug!! The switches for the electrics touch the side of the car!!!
Has anyone hear had a similar problem and if so how did you get round it.
Thanks
I decided against the Rover seats as they are just too large. I am going with MGB seats fitted to the original bases. Others have fitted later MGF seats and they look very good, both are that much smaller than the Rover seats but the Rover seats have that advantage of cost.
Yes I agree the rover seats look big but I did a £500 car challenge last year 8 countries in 4 days in a rover 75 and it was soooo comfortable. I want to tour the kit car so comfort is a priority
Thanks for the reply though
I fitted MX5 seats but had to make up square section bracket that bolted straight to the car floor using the existing fitting for the BMW seats, very comfy with plenty adjustment if your tall. Good luck with the build.
Trev
Trev
Thanks Trev
I am going to weld some extra bracket for my rover seats. I am only 5 feet 5 inches and wife is smaller so seat height is ok
Thanks
I think people fix the controls to the bottom front of the seat with cable ties
Had a good look at the job the other day and have taken all the plastic off the side of the seats where the switches go and am going to reposition the switches on the console behind the handbrake.
Have you bought a set of instruments?
If so a detailed step by step guide with a wiring diagram would be a great addition to the site.
I am very tempted to buy a set when funds allow but the wiring frightens me.
Yes, just bought the gauges and I will post installation procedure in a few weeks when I get to fit them
Thanks
Here are some instructions that came with the gauges
I have these gauges in my mirage 250 , how do you set the time on the clock?
does the little knob need pulling out to wind it to the correct time .?
The instructions say to put a finger on the chrome advance knob (don’t press it) and after 4 seconds it will begin to advance.
I have taken a photo of the instructions for you
