fuel level sender
24 Oct 2006, 11:01am
Went to mount the sender supplied by marlin into the tank;The tank has 6 mounting holes with riv-nuts and thus doesnt fit with a 5 holed sender.Any ideas guys?The obvious painful solution is to patch the tank and start anew for sender unit.cheers
24 Oct 2006, 11:04am
As I posted in the other thread:
Our Marlin supplied tank didn't have any holes, we did that ourselves:
http://www.msportster.co.uk/detail.asp?cat=7&offset=180
Needed a load of gasket sealer to stop it leaking. Nice and solid now though! :) Some of the other builder have used much more elegant solutions. Have a look through some of the other build sites :)
24 Oct 2006, 4:20pm
fuel level sender
Spoke to marlin today;The tank I got at the time was drilled for a unit that has since been discontinued--my fault for not building when I bought the kit!My only solution is to cut out this mounting from the tank,alu weld over, and mount the new sender with its glorious 5 hole flange!
