Wiring up
Howdy doody all.
Another reefugee from piston heads here. I have a Dax Rush on order and will be slipping a rover v8 under the bonnet. I am not bothering with a donor car but getting most bits already refurbished. One item I was looking to save cash on(just the one I hear you cry) was the wiring loom. I was planning on making it myself. Does anyone have a wiring diagram for a simple car layout. Saves me having to trawl through a Haynes manual with the ladybird book of electronics. I used to wire generators so am adept with the crimpers and cable wrap Thanks in advance. L |
Liszt,
You won’t escape from me that easily :eusa_naughty: ! I’ve got just the job for you. I’ll e-mail a diagram tomorrow. Used to make them for the Sumo MYSELF and I designed it, so should be able to help with alterations and/or talk you through any problems. Buying the wire by the 50m roll the materials used to cost only £15. Problem is you won’t need more than about 5m of any particular colour, unless you want to make a batch of 10. :eusa_doh: . Might make an interesting article too! But don’t let this reply stop others responding :eusa_hand: . Liszt might not want to deal with me after the ear-ache I cause him and everyone else on PH. Den. |
Cheers Den.
Having seen sme of the looms used in the Power control industry I know I can make a very good job of it. Also happen to have a ew pieces of wire and the odd terminal or 2 hiding in the attic It is also easier to ask for something that has alread been done than reinvent the wheel. |
