Using a MX5 rear end on a registered kit, IVA ?
Hi all, i am thinking on upgrading the rear end on my kit car, at the minute its is registered, but it is running a MK1 Escort rear axle on 5 link setup.
Now the idea is to swap that for a complete MX5 rear subframe, so subframe,diff, shafts hubs all but the Shocks, i will use the coil over i have so just new tabs for mounting them. Question is, if i do this will it be back to an IVE test due to the work done? wolly :) |
If it has already gone through the formal registration process (IVA or VIC etc) and is registered correctly why would you want to offer it for re-inspection? I doubt that the original rear suspension type was recorded when inspected for the first time. Take a look at INF26 click her |
Its not that i want to put in for a IVA again, be mad to want to as it will never pass nowadays. Just wonder if it is allowed to be done without needing to be inspected again, i have had different things said, as its a suspension modification so will not be allowed with out be inspected once done.
I cant see the problem but i dont know all tat much on the changes allowed to be done. i tryed to call the local VOSA IVA point but no answer for a few days. i will have alook at the link you gave, thanks for that kida. wolly |
Absolutely no need for IVA at all..........
