Sportster Camber Angle Adjustment
Can somebody inform exactly how is the camber angle adjusted on the Sportster . I can see a camber plate or camber bolts which typical methods of adjustment , I believe mine are around 2.5 + deg neg which seems and looks excessive.
You have to first remove the long rod that holds the upper wishbone in place to rotate the bush tubes. |
Peter is correct camber is adjusted by unscrewing the threaded parts that hold the bushes. Caster is done but moving washers either side of the top wishbone mount.
My post from when I set the car up in 2008: https://www.msportster.co.uk/2008/05...-the-handling/ Tried to copy and paste it into the post 3 times but the text keeps disappearing, hoping the link will stay |
Got your comment on my site:
To adjust - support the chassis with a jack unloading the suspension. Remove the nut either end of the top wishbone on the chassis side and pull out the rod that goes all the way through. https://www.msportster.co.uk/gallery...-1024x768.jpeg This is an old photo with the stock for ford TCA bush (Marlin since stop selling these and only supplied the powerflex ones in the above photo) as well as showing the wishbone installed up the wrong way. However it does how the threaded part used to adjust camber. Undo the nuts and twist them in or out on the thread to make the wishbone longer, or shorter, as needed. Make sure they stay the same length relative to each other. It's a pretty slow process setting this up as you need to assemble the whole thing, put it on it's wheels bounce / move it and re-measure. https://www.msportster.co.uk/gallery...truction36.jpg |
I had some questions come through on my site on how the camber and caster are adjusted on the Sportster. Excuse my poor CAD drawings they are not dimensionally accurate, they only represent the adjustments available.
Forum keeps deleting half my post, please view article on my site instead: https://www.msportster.co.uk/2023/11...er-adjustment/ |
