28th July 2017, 20:51
Finally plucked up the courage
Eventually started my mx250c after having bought everything in January/February 2016.
I decided there is never a good time to start, so went for it. The weather is always too bad or too nice to start destroying a good soft top!
Within the afternoon I have the back end stripped and I am ready to start riving at the bodywork.
Any tips are greatly appreciated. I'm using a 1998 mk 2. I will be posting pics of progress as the weeks go by (or months)
29th July 2017, 06:30
Good luck, remember to keep posting.
8th August 2017, 18:32
Hi, I have built two mx250c 's now. A mk1 and a mk2.
If I can help just ask
8th August 2017, 22:43
Great. I have the back end removed now and need to start opening up the wheelarches. It's the bit I'm not looking forward to.
9th August 2017, 17:16
What plans have you got dude? In terms of colour? Wheels etc?
11th August 2017, 05:15
I'm thinking green with yellow racing decal. It may sound awful but it looks good in my head. I've seen some lovely wire wheel alloys on this forum which are a definite too.
12th August 2017, 05:40
daveytz – A belated welcome to the forum.
This green with orange highlights combination is one of my favourite MX250s.
But as this is a mock up of what my own colour scheme will look like, I might be a bit biased.
Do you have any photos of your own build?
25th September 2017, 19:47
Evening chaps. I'm trying to fit the front end but there is a vertical plate at the front end where the bonnet starts. This interferes with the front sitting right and looks like it shouldn't be there but dont want to cut it off yet! It hits the frame so the whole thing sits really high. Any suggestions?
25th September 2017, 21:07
Do you have a picture?
26th September 2017, 15:51
I will sort one out tomorrow. Trying to fit in working on her between work and the weather!
26th September 2017, 15:53
How do you add photos on here? .
26th September 2017, 16:03
I'm trying to add a photo from my phone which shows how high the front and is sitting.
26th September 2017, 17:37
That is not right.
Take a look inside , from memory I think I removed some material from near where the headlight bowls would sit . Get the grinder out, but measure twice and cut once.
26th September 2017, 18:03
body fit
Yes cut headlight bowls so it sits right. Its not a hard kit to fit just needs fettling.
26th September 2017, 20:28
I know the headlights ate interfering with the front end but there is also a strip which looks like it should slot in front of the radiator bit it sits too far up if it goes there!
27th September 2017, 15:49
Remove it
27th September 2017, 15:52
Cut all the holes for the front now, and then at least you can see where its fouling
27th September 2017, 20:37
Here is the strip I was talking about. I will remove it as said.
27th September 2017, 20:48
28th September 2017, 09:57
Yes remove the fibre glass bit, I did 👍
