Old 15th April 2014, 13:29
striker1660 striker1660 is offline
striker1660 is on a distinguished road
Default Gt6/vitesse parts
I have just picked up a new project Corsa type 48 which has some surplus parts. So if anyone needs parts see below. I don't know how to load photo's but can send directly.
parts
Fully reconditioned rimmer bros gt6 mk2 gearbox and other triumph's with overdrive, bell housing, thrust bearing, also new clutch/plate as new in the box.
fast road spec. distributor from jigsaw with blue silicon leads, coil ,plus two distributor caps and points etc.
Rimmer bros. performance gt6 manifold & exhaust system stainless with single box normally around £500/600!
ABS Plastic gearbox cover
gt6 front uprights with trunnions used
hi torque starter motor for straight six
LRA 100 Lucas alternator
brake servo
two 150 strombergs with polished pancake air filters
chrome filler cap ( flip lid)
kenlowe thermostat control knob
straight six oil feed kit
please e mail me and I can respond
Old 15th April 2014, 13:59
Originally Posted by striker1660 View Post
...hi torque starter motor for straight six...
Would this work with a 1980 Spitfire 1500 engine?
I'd be interested if it did, but know next to nothing about this sort of thing.
Nice kit project.
Old 15th April 2014, 14:07
Default hi torque starter motor
Paul not sure , it the flange that's likely to be different which is probably available form the specialists. Canley, rimmer bros
Old 15th April 2014, 14:22
OK, I've just had a look at Rimmer Bros.
Spitfire
GT6/Vitesse
Clearly they are very similar, but not quite the same, so "I'm Out".
And I only recently bought a new gearbox cover too.
