Old 9th July 2018, 20:26
cbjroms cbjroms is offline
Default Sammio Fuel Tank
Early in my build (ie many years ago) I got hold of a Spitfire fuel tank, cleaned it out, fitted it and filled it with a couple of gallons of petrol. I now find that it has deteriorated somewhat, fuel has gone stale and I am having to recondition my fuel pump, lines and carb.
So I have removed the tank and found that it is has a fair amount of rust inside. Not sure whether to go down the POR15 tank sealer route (which seems to get good reviews) or replace the tank. A brand new Spitfire tank is around £250 but I have noticed lots of new MG tanks for not much more than £100.
Any thoughts and advice would be greatly appreciated. In particular has anyone used the POR15 tank sealer and/or found a tank from another vehicle which readily fits the Sammio?
Chris
Old 9th July 2018, 21:06
I haven't used POR15 tank sealer but recently used their paint process , which was very impressive ...
Basically , any tank that fits , can be used within reason ...you need to be aware of the sender compatibility , one of the reasons a Triumph Spit tank was adopted for the S*mmio range ..but a whole heap of BMC style tanks can be made to work ...I have used Morris Minor , Austin etc with no real issues ...in theory the MG should work but Im not sure of their dimensions or cap location ..
Old 10th July 2018, 09:09
Lightbulb
Basically , any tank that fits , can be used within reason..
Hi Chris
I used one of these in my pre-lit Westfield Seven. They're very adaptable and the sender will be compatible.
Regards, Mick
Old 10th July 2018, 09:40
wharfedale wharfedale is offline
wharfedale is on a distinguished road
Default tank
fit a good quality cleanable filter and carry on regardless.
I had the same problem and my tank was fitted befor the body so removal was not an opption, I fit an old filter with removable glass bowl and just kept cleaning it till it ran clean. Keith
Old 9th August 2018, 10:29
Thanks for the advice above.
I ended-up using electrolysis on the tank for a week and then the PO15 tank cleaning/sealing kit. Difficult to get any meaningful photos of the inside but it looks GREAT.
Old 9th August 2018, 20:51
Chris - Glad to hear you got your petrol tank sorted.
Perhaps it is now time to bring your build thread back to life?
