22nd June 2014, 10:36
PMed - as agreed. Have arranged for Chris to fit it during the build.
Collecting car on 5 July.
26th June 2014, 17:25
Rubber
So- the inner tubes have arrived and I've ordered the tyres. Thought I'd start with some 195/65 x 15 V-rated Falken AS200 all weather tyres. They are snowflake marked so have a high silica content. With that skinny width on the 5" Jag rim, I'm looking for all the grip I can get.
28th June 2014, 18:13
Progress
Rear light and plate position now fixed
Side vents cut and bonded, just require some filling and priming in white
28th June 2014, 20:29
Cleaned and sprayed the wire wheels silver today. Arranged to have the new rim bands, inner tubes and Falken tyres fitted tomorrow morning.
28th June 2014, 20:30
Lights
Thanks for the call Chris. Lights look OK, shame we need so many now!!!! The tub looks quite thick there so may take the flattening for the base of the lights without needing any strengthening from behind.
Reason: Tidying
29th June 2014, 08:48
Make sure you stop by my house when you pick it up. It will be good to see the black and white twins
29th June 2014, 10:45
That is my intention. It will still have the starfish wheels but I have some stickers to cover the centre badges.
3rd July 2014, 19:21
4th July 2014, 09:17
Nice fuel filler - Look forward to seeing that on Saturday on your way past
4th July 2014, 22:02
Nearly there on Ian's build. Another headlight to fit and then fettling this and that before a spot of filler here and there, and some white spot primer. See you on Saturday Ian.
Wow
5th July 2014, 19:48
5th July 2014, 21:18
It was great to see Ian's car. It reminds me how much work I have done on mine and how much fun it has been.
So much better than re-laying the patio which is what I was doing today.
6th July 2014, 10:14
Ian came down to collect his Z300S today, he was really pleased with the stage the car was at. We were asked to build to a driving condition that Ian can detail and paint in his own time.
I am guessing he enjoyed his drive home to Oxford, via WCA's house:
Too right, Chris. many thanks for a great job. Everything works- it's a practical everyday car already. I'll be back next week to collect the remains.
6th July 2014, 11:06
Yes, good to see #1 and #4 together. I think that my white colour scheme will be more sympathetic to the grp material of the car whereas black sets very high standards for preparation.
If only all grp paint jobs could look as good as yours...
6th July 2014, 11:10
Watching that vid over and over- what a machine !!!
6th July 2014, 14:50
much prefer it with the bonnet scoop filled in
6th July 2014, 21:48
Glad you are enjoying the car and the video. It"s so easy, with smart phones, to do videos now that I should do it more often.
7th July 2014, 07:40
defo, a picture canpaint a thousand words...
13th July 2014, 12:53
Just driven 230 miles in my Jago- the last 120 miles like this
13th July 2014, 20:51
In all its wire-wheeled glory
Dry fit and exhibition revs only.
I fitted the MWS Jaguar wire wheel adapters today and here it is:
The adapters fitted perfectly in terms of bolt PCD and diameter. There was <1mm play against the hub centre as well- result.
My only reservation is that the holes in the adapters are 45deg countersunk whereas the bolts have a 60deg bevel. The standard bolts clear the curly hubs. I did try my cone washers but that would need the bolt heads to be trimmed slightly. I'm not convinced that the washers are the best solution anyway- anyone know of 45deg chamfered wheel bolts? M12x40mmx1.5mm pitch?
