Old 23rd February 2014, 13:28
Viatron Viatron is offline
Default Update 2 Saturday 22nd Feb
Once I had done as much as I could on the body I moved onto the electrics. I have decided that now I don't need to worry about doors I will get the electrics pretty much done and the car running in moon buggy format before fitting the body, this will hopefully mean that I wont have to spend time upside down with my head behind the dash trying to sort wiring issues.
Got the NoDiz fitted, it will eventually have an Ali plate to attach too but just cable tied it in place for now so I can work out the cable lengths.
Got all of the starting and charging wiring done and tested. Needs final tidying but will look much better once its all sleeved.
Managed to get the ignition switch all wired up and tested as well, the loom that I bought from Langys Rod Shop is a dream to work with and I haven't had to look at the instructions yet as everything is so clearly marked it all sort of falls into place.
Got the steering column remounted ready to do the wiring to it but realised I didn't have the right plugs as I want to make the column removable without having to cut wiring.
The best part of the day was when I turned the key first time and the engine turned over with no dramas and no escape of the dreaded loom smoke! The combination of the geared high torque starter and a small racing battery worked fine and spun it over very quickly even though the battery hasn't been charged in about 12 months...result!
TTFN
Mac
Old 23rd February 2014, 15:33
Next step is the first fire of the motor then. That's a biiiiiig step...
Old 23rd February 2014, 18:26
Yep, if the eBay twonk who is supposed to be supplying me a custom trigger wheel ever does, nearly 3 months now! Time to find someone else as I don't want the lack of a trigger wheel holding me up.
Old 24th February 2014, 13:04
Mac - Great progress.
I'm looking forward to seeing you reach the moon rover stage.
As it will be a big target for me to follow.
Old 3rd March 2014, 14:08
Got some bits and pieces done on Saturday.
Welded in reinforcing bars now that the doors are shelved.
Also got the wiring sorted for the headlights and sidelights, horn, and ECU, bit of a head scratch on the horn until I realised it earthed via the column itself which wasn't connected yet!
Old 3rd March 2014, 14:11
quick visit to the workshop today.
Indicators wired up and Bluetooth connection with the ECU established and tested. Ordered some custom length plug leads. Just browsing now for the least few bits and bobs to finish the wiring. Found it very handy using a trailer board to test the rear lighting rather than faffing around with the actual lamp units themselves.
TTFN
Mac
Old 4th March 2014, 21:21
Pooh shiny stuff, just had the nod that my badges are done,
Old 7th March 2014, 18:04
Badges arrived today and very lovely they are too! I should hope so at the price!
Also took delivery of what I hope is the last of the electrical bits n bobs including a nice chromed rear fog light, not going to bother with a reversing lamp.
X3 pull switches, hazard, rear fog and map light
Combined Ignition and light switch
And the Weber TPS kit
Up the workshop tomorrow so hoping to get most of it wired in and tested.
TTFN
Mac
Old 8th March 2014, 18:59
Good day in the workshop today.
First job was to fit the TPS to the Carb in readiness for the arrival of my trigger wheel which will mean engine startup...gulp!
Couple of issues I encountered were:
1. TPS is made to go on the right hand side of the carb, just where the throttle linkage is in the Weber supplied kit???
2. The main mounting bracket is supposed to screw to the body using 2 threaded holes in the casting, my carb only has 1!
Swapping the linkage wasn't to bad, had to bend the throttle adjustment stop 180 deg so it would work on the other side and will have to figure out how to fix the cable stop as its currently mounted using a nice cast mount point which is now on the wrong side, worst case scenario I will have to tig a block onto the manifold.
The missing mounting hole can be sorted with a strip of Ali from the trumpet retaining nut back to the mount, ill do it next time im up the workshop.
The almost finished article :-)
TPS mounted, you can see the nearest mounting hole is currently mounted to thin air
The throttle linkage now on the other side, the throttle arms on the right is only pointing up as I still need to work out mounting the end of the cable.
Next job was a bit of Ali fabrication
Can you guess what it is yet?
Its made of 5mm Ali plate and is the soon to patented combination mechanical fuel pump blanking plate / Ford Gen 2 coil pack mounting bracket. best your still none the wiser. At this stage I was hoping to Tig it up and get the coil pack mounted as I received my nice custom plug leads yesterday. Unfortunately some idiot forgot to turn off the gas at the cylinder last time he used the TIG and the bottle is empty so have ordered a new one and given the offender a good talking too, subtle hint is that I was alone today as Dave is currently on DIY duties allocated by his SWMBO.......
Moved onto the wiring again, got the rear loom all bound up in very fetching red spiral wrap and finally secured, Tick!
Nest I started to undo some of the work already done so I could use the lovely retro combined ignition / light switch. A couple of issues as its a simple on/off key switch with an accessories position but I found some natty little bus bars I had lying around and soon had the ignition switch working along with a nice little high amperage push button to start, all tested and signed off...Tick!
Next was the lighting which had me scratching my head as the switch uses the main feed into the switch for the ignition to power the lights but the loom has a separate fused supply for the headlights... 2nd bus bar fitted and the side and tail lights now work fine off the switch. ended up doing a bit of lateral thinking and used the headlight feed off the switch to trigger a relay so I could continue to use the loom fused power to the headlights via the column switch. By the end of the day I had power in all the right places at the right time without loss of loom smoke for
Sidelights
Headlamps Dipped
Headlamps Main Beam
Headlamp Flasher
Was enjoying myself so much I was interrupted by a call from home to ask where I was as I should left an hour earlier!
Hopefully will get some more workshop time next week as I am between projects, hopefully at Least 2 days so my aim for next week is to get the motor running...GULP!
TTFN
Mac
Old 9th March 2014, 18:44
Mac - Sounds like you are getting lots of loose ends tidied up.
Hope all goes well with the engine restart.
Old 10th March 2014, 19:18
Managed to get a few hours in and finished most of the wiring with the exception of the instrument cluster.
Rear Fog Light tick!
Hazard Warning Lights tick!
Wired up the front P700 headlamps with new H4 connectors, the headlamp bowls now have a nice pair of waterproof connectors on them, a 3 way for the headlights and a 2 way for the side lights. Went to try fitting the chrome headlamp rings and they seem about 1/2" too big?????? anyone else had this issue?
Old 10th March 2014, 20:13
The 1958 Rocker The 1958 Rocker is offline
The 1958 Rocker is on a distinguished road
Not sure Tron, but got a feeling P700 lamps have a slightly different chrome surround. Think I saw it on a kit car supplier listing with two sizes of chrome trim. Worth a look.
Simon
Old 11th March 2014, 07:25
I used second hand Austin Mini chrome trims and they fitted just fine.
Old 11th March 2014, 08:42
Towed, what sort of gap do you have between the inner ring and the outer?
Mac
Old 11th March 2014, 18:02
Mac
No gap, they're a firm push fit over the lugs on the inner rings then secured with a screw at the bottom.
7" Mini chrome trims like these -
http://www.ebay.co.uk/itm/Classic-Mi...item2ecf66be19
Old 11th March 2014, 18:28
Hello Mac,
I have tripods (not original) and I use Mini rims. It was a good fit.
Michiel
Old 12th March 2014, 07:29
Yep, same here, Lucas P700 replicas from ebay plus second hand classic Mini chrome trim rings = perfect fit -
Old 12th March 2014, 10:42
Had another look and I think the rims may be ok, the problem seems to be the fixing of the ring, they have a single screw but although the plastic back shells have a hole for the screw they don't have any other ay of locating the ring. I think im missing some clips? anyone remember what there's were like? even better anyone got any pictures of the retaining clips?
Mac
Old 12th March 2014, 10:59
Hi Mac,
I don´t think there are clips. When the plastic bucket is mounted. In the right position. And that is with the fixing screw downwards. Not totally 180 degrees downwards (as I did), but lets say 175 degrees. (this is because the headlamps are fixed in a rim and the lamp can not turn. That rim is screwed into the bucket. This means that the position of the bucket determins the position of the lamp. And with tripods you can not smugle without noticing that the lamps are turned a few degrees out of line.
You will notice that there is a very small edge on the above of the bucket. You can hook the rim behind it. At the underside you fix the rim with one screw.
Hope it helps and that my bad English is enough to explain these details.
Michiel
Old 12th March 2014, 14:54
Michiel, thanks for taking the time to reply but my trim rings at the moment will only be held in place by a single screw and as they are not a tight fit im sure there must be a clip either missing on the trim ring or on the plastic bowl otherwise the ring will just be flapping around on a single screw with nothing keeping it secure 180 degrees from the single screw.
Anyone else?
Mac
