Old 26th October 2017, 18:35
rossnzwpi rossnzwpi is offline
rossnzwpi is on a distinguished road
Default Lotus Europa spring rates
Just as a comparison the spring rates for a Lotus Europa are:
OEM S2, 100lbs/ins Fr, 72lbs/ins R
this is another lightweight fibreglass kit car. The front spring is on a similar angle to the Deon:
and the rear is fairly upright:
Old 26th October 2017, 21:16
Dodo87 Dodo87 is offline
Dodo87 is on a distinguished road
Thanks for your informations.
Old 27th October 2017, 07:24
Smile
Hi, If someone could give me others brends of dampers, It would be good for me because I'm not in England! Thanks.
Old 27th October 2017, 08:39
NeilF355 NeilF355 is offline
Originally Posted by Dodo87 View Post
Hi,
Can you give me, please, your damper references?
Regards
Hi
I am building a Classic replicas Dino at the moment. I think the suspension set up is the same as the Deon.
I measured my compressed and extended lengths between the coil over mounting bolts on the car’s suspension and supplied the info to guy over here in the UK who then supplied me with GAZ coil overs.
The details were as follows:
Front:
Coil over extended length 260mm (10”)
Compressed length 180mm (7”)
Rear
Compressed length 207mm (8”)
On the basis of the above he sent me GAZ shocks model number 100/075 R12-2.
A friend of mine has Protech Coil overs on his Dino. I contacted them before I bought the GAZ ones, Protech were almost double the price of GAZ.
Good luck with the build
Old 29th October 2017, 22:29
Hi, thank you. Can you put, please, some pictures of your car? Regards
Old 30th October 2017, 08:48
I've PM'd you
