Old 18th April 2017, 16:03
After four years on the road I have decided that my main bonnet scoop, which had kind of morphed into something much bigger than I intended when I started trying to clear various ancillaries beneath, was just too wide for my liking.
So, after taking a very deep breath, I've cut it out and am in the process of replacing it with something that looks far more in keeping with the original D24 Spyder -
It's still very much a work in progress and what you see in the pics is actually a buck to take a mould from before laminating a complete new centre section for the bonnet. Once that's done a full respray in silver (naturally) will follow. Timescale is before Stoneleigh, weather permitting...
Old 18th April 2017, 18:33
Towed , that looks so much better ...I didn't have too much of an issue with your previous one , but that is so much nicer ...as you say D24-esque , which is cool ... asymmetric wing scoop next ?
Old 18th April 2017, 19:13
Been thinking about it. I still don't know what they were for though...
Old 18th April 2017, 19:29
Nor me ...if the one that was at Goodwood a few years back returns , I will make a point of trying to ask the owner , as its been bugging me for years !!!
Old 18th April 2017, 20:11
Mr T - Hard to believe you have been on the road for 4 years!
Nice job on the bonnet, and I'm impressed you are making a buck/mould.
Old 18th April 2017, 20:17
micky1mo's Avatar
micky1mo micky1mo is offline
Looking good.
Old 18th April 2017, 20:36
swifty's Avatar
swifty swifty is offline
Looking more like a D24 scoop.
I to have wondered what the wing scoop is for, did think of adding it to my build when doing all the alterations.
Old 18th April 2017, 21:23
kevemm kevemm is offline
kevemm is on a distinguished road
I think its going to look great much more subtle. Good work
Old 18th April 2017, 22:02
That's looking really neat.
Old 19th April 2017, 07:02
Jaguartvr's Avatar
So much better, well done for being brave and cutting up a finished car to improve it.
It will be well worth the effort.
Old 19th April 2017, 07:58
Thanks everyone, it is beginning to look much more original than my 'wide' scoop.
That wide scoop had started as a nice, narrow opening to take an original style scoop about 40mm high, just to clear the rocker cover. It then needed widening on one side to clear the dynamo and engine top hose, and on the other side to both centre the scoop on the car and clear the front carburettor.
Then after many cups of tea and much staring from all angles and beard scratching I lowered the bonnet at the front to get the wheels looking 'right' in the arches. That meant that the sides of the scoop had to get a fair bit taller too.
The side bulge was added to clear the front corner of my alloy air box that was part of the methanol injection system, while the secondary scoop was added purely for decorative effect, as were the aluminium louvres towards the back of the bonnet.
What I ended up with looked okay, but it wasn't how I had envisaged it so it's mildly bugged me ever since.
Over the course of the last four years I've made a few changes under the bonnet which have now allowed a slimmer, more original looking scoop to be created:
The dynamo was 'rolled' down and a new bracket fabricated so it's out of the way completely;
The methanol injection system was removed - even though it really worked when it worked, as the engine isn't mega powerful the small quantity of methanol/water mist required meant that the nozzle was so fine it kept blocking despite the filters in the plumbing;
I've raised the rear gearbox mount by 20mm, which dipped the front of the engine down by 10mm (that mod copyrighted by Phil J);
I cut the elbow off the thermostat housing hose connector which frees up a surprising amount of space to the side of the rocker cover.
Taken together, those changes have removed a lot of the obstacles under the bonnet and mean that only the rocker cover and the very edge of the top hose need clearance now, and the new scoop is taking shape nicely.
As for the wing scoops on the original D24's, the answer may well be lost in the mists of time. Only two of the six built survive and no two look the same in period pictures.
Lancia clearly believed in developing their cars on the track - including hacksawing the roofs of the D20 coupes when the drivers complained that the cabin was too hot - and the rows of solid rivets holding the wing scoops on suggest that they were added after the bodies were finished by the coachbuilder.
Additionally, there are a number of 'continuation' models out there that were built in the 80's or 90's (using original engines and factory blueprints), which have wing scoops but may or may not have the additional widgets beneath that they serviced.
I guess a visit to the Lancia museum (if I can work out where it is) the next time I'm in Italy is on the cards to try to find out more.
Oh, and while I was looking for details of the continuation cars I came across this article about recreating a Lancia D50 -
https://www.classicdriver.com/en/art...grand-prix-car
How the other half live...
Old 19th April 2017, 12:49
Marc F Marc F is offline
Oh my, I love the D50 and often wondered if it would be possible to build a "look-alike" - but that build is in a different league altogether.
But
Back to your car - yup, love the new scoop - much cleaner looking. And love how our cars can be subject to this on-going process - so much more fun than a rep-mobile
Old 20th April 2017, 16:00
phil9 phil9 is offline
wing scoop was for brake cooling
Old 20th April 2017, 17:44
Jerome Jerome is offline
Jerome is on a distinguished road
Looking great!I just love changing/improve things on the car during the years.
Gr.Rob
Old 24th April 2017, 15:40
Progress report - I got the new scoop arrangement all smooth and blended in to the bonnet and sprayed it with etch primer by Friday afternoon. It's great this retired business, I actually have the time to get on with stuff!
Next step was to give it a coat of rattle can paint followed by a dozen coats of mould release wax polish then take a splash mould ( I think that's what it's called) of the whole centre section of the bonnet. But...
Before applying the paint I stood back and took a long look at the new scoop arrangement and there was just something that didn't look quite right.
It took me ages but it slowly dawned on me that there was a slight, but annoying mismatch, side to side, in the height of the edges of the raised section ahead of and alongside the new centre scoop.
After a lot of checking with a spirit level and steel measure, I worked out that it was down to the curvature of the original bonnet not being even between the wings, and the width of the raised section exaggerated what is a relatively small difference into something noticeable.
So, I cut the centre section out and started again. It's still a work in progress but it now looks 'right' to me from all angles, which it just never has done before - my original wide scoop sort of evolved as it went along and even though the perfectionist in me wanted to cut it out and start again, the realist in me said if I did that with everything I wasn't 100% happy with I'd never get the car on the road.
So, it now looks like this -
It's definitely going to stay that way once it's had a bit more work and I've moulded and bonded in the complete new centre section, and there's the added bonus that I'll now be able to have a roundel on the nose just like the original -
The donwside is that I'm no longer on schedule to finish the current revamp before Stoneleigh, so I'll be driving over in my modern tin-top
Old 24th April 2017, 16:59
That's a shame about stoneleigh. I was hoping to see your car there. Wonder if any other owners will brace the weather?
Old 24th April 2017, 18:08
LOOKING GOOD TOWEDY ...
Discrepancy in the bonnet side to side ....? surely not !!
Old 24th April 2017, 18:18
I seem to remember that was the day I realized the knotty string wasn't evenly spaced ....
Old 28th April 2017, 16:30
Mr T - Well, if you are going to start chopping things about, you might as well get it the way you want it.
Good Luck, Paul.
With a bit of luck both our cars will be painted before we finally meet up.
Old 29th April 2017, 06:59
Good Luck, Paul.
Let's hope so!
