15th June 2015, 13:20
Exhaust help
Anyone know where I can get straight through twin exhaust pipes for my kobra bmw z3 build, either with or without a back box ( preferably without ).
Reason: photos added
15th June 2015, 14:11
Hi,
Not sure where you are, but if you're in the Norwich, Norfolk area I can recommend Mark at Power and Performance (01603 880060). He makes one off stainless pipes and would be able to supply and fit whatever you fancy.
I've been using him for many years as he also does a lot of varied hot rod work.
My 250swb will be up there tomorrow while we try to work out the central locking and I look how he's getting on with my wheels.
15th June 2015, 14:13
Thanks Bob
I am in Dorset but will give Mark a call to see if he can help
Wolfie
15th June 2015, 17:45
If you find a good one in Dorset please post the details here. i am in Southampton and will need new pipes soon enough
15th June 2015, 19:44
If you can measure and spec the pipes yourself, well worth contacting :
PIPE WERX
ian birch
The Old Woodyard, Carr Lane, Lathom
Ormskirk
Lancashire
L404BT
United Kingdom
Phone:01704 895252
Email : pipewerx@hotmail.co.uk
Company registration number: 7250922
VAT number: UK 100393169
to get the pipe cut and bent and sent to you.
I've used them a few times for odd bends and tail pipes. All stainless and reasonably priced.
15th June 2015, 19:47
Performance 3000 in Yeovil make exhausts, Set up coil overs etc
01935 427554
I haven.t used them yet but will be going there when I need my exhaust
15th June 2015, 20:37
Im still to do mine on the kobra but noticed a sensor at the end of the backbox. Whats this for? Can it be disconnected?
15th June 2015, 21:08
Is it the vacuum operated flap valve? I just sealed the end of the tube and stowed it securely. Fed from the engine somewhere?
16th June 2015, 11:35
Is it an oxygen feedback sensor or similar?
I suspect it should be kept in there somewhere.
29th June 2015, 06:10
message for WCA
John Stokes of Bournemouth have given me a quote re: exhaust pipes -
You will be looking at approx £350-£400 with a box and around £250 to go just tubing and tails.
Not sure if these are good prices or not - what do you reckon ?
Wolfie
29th June 2015, 07:13
I'm lucky enough to be able to make my own for pennies, so that price horrifies me, but it beats the £1500 price tag for an XKSS exhaust!
Is it not possible to remove the baffling/ padding in the original exhaust for a better flow?
Perhaps slice open, remove then weld back up?
29th June 2015, 07:21
Hi Scottie
Im afraid thats beyond my capabilities, I am building a kobra and wanted twin exhaust pipes coming out of the back, im not much of a mechanic and this is my first kit car project.
29th June 2015, 07:37
Hi,
I guess the photos in the original post are what you are looking to do with your car. I am have a 250 SWB kit on order and want twin pipes also, I am in Milton Keynes and phoned a local builder of custom exhausts and they said a twin stainless exhaust (I have 2 pipes running along the bottom of the car as I have a 3.0) would be in the region of £650.00
29th June 2015, 08:14
Both those quotes seem about right unfortunately.
Need to get Scottie practicing his stainless welding and then turn up with some tube and doughnuts :-)
29th June 2015, 09:15
Originally Posted by ericholm
...I am have a 250 SWB kit on order and want twin pipes also, I am in Milton Keynes and phoned a local builder of custom exhausts and they said a twin stainless exhaust (I have 2 pipes running along the bottom of the car as I have a 3.0) would be in the region of £650.00
I'd be looking at something like this for a quad pipe setup (or similar with just twin pipes) and extending the tailpipes with stainless to the right length. Would also need a 2into1 in front of it to accommodate your existing pipes.
29th June 2015, 13:08
Umm, wont putting the exhaust from 2 pipes down one be a little restrictive? I was looking and thinking of something like this:
29th June 2015, 19:03
Umm, wont putting the exhaust from 2 pipes down one be a little restrictive? ...
Providing the single pipe is of a larger diameter than one of the duals and the silencer is of the straight-through variety, it will just increase the gas speed and change the note. Probably not much, if any loss in bhp on a road tuned engine.
I wonder how much those portable dynamometers are? I was quite disappointed that they didn't have one at Stoneleigh this year. I wanted to do a before and after with some Activ8 oil additive in the engine.
