8th February 2008, 11:51
Mikes BMW Marlin Cabrio
Big hello to you guys who regularly use madabout....
Many thanks for the hours of pleasure I have had looking at your builds and the different solutions you have each found to similar problems/opportunities.
I hope you don't mind us Cabrio builders piggy backing your Sportster site - but we do have a genuine interest as some of us have gone down the BMW route.
I have chosen to fit an E36 M50 vanos in to my Cabrio - and have finally been spurred in to joining madabout by Rob Dorey's entry , as he has a M50 engine.
Rob, do you have any photos of your build? I would love to see how you are getting on. How have you dealt with the electrics - did you use the BMW's own loom, or buy a new one?
I am some way behind you guys with my build, but have made some changes to my chassis which may interest you. If interested I have also opened up a flickr account: www.flickr.com/photos/mikes_bmw_marlin_cabrio
Hope you like them: and many thanks for enlightenment over the past 18 months.
regards
8th February 2008, 12:08
Welcome to the forum Mike.
8th February 2008, 12:42
I spent many happy hours sat on an old office chair with the old loom spread out on the garage floor. Stripping out the circuits I didn't need, so that when it came to the build I could keep to the BMW colours.
The main problem I had was trying to fit the 2 computers(ABS & ECU), fuse box and most of the relays under the passenger side and still have enough room for someone to put their feet in. And actually, looking back, it wasn't so hard and was a joy to do.
I've tried to use as many unmodified parts as possible from the donor car to make life easier if something breaks.
8th February 2008, 13:02
Hi Mike - Nice set of pics. Loving the engine hoist!
8th February 2008, 13:07
hi Mike
8th February 2008, 21:34
Yeah, great set of photo's and some very interesting and adventurous mods.
When did you take delivery from Marlin? It must be one of the last ones they did.
cheers
Peter
9th February 2008, 19:18
This raises a good point actually. With Javelin continuing the Cabrio and utilising BMW goodies, what do you guys think about opening this forum up to Cabrio builders or would it be better to create a new forum for Cabrio builders (assuming there is demand for one of course)
Quite happy to be guided by the masses.
9th February 2008, 19:36
Hi John
If you remember it was me that suggested you start the forum :-). There aren't a huge number of Sportster or Cabrio builders (so it seems) and as there is a lot of commonality between the cars my vote would be to open the forum to both. What do you other guys think?
9th February 2008, 19:39
Hi John
I agree a combined forum would probably work quite well
9th February 2008, 20:06
John,
I think we have already made Simon and Mike welcome and the cars are quite similar with their clothes off!
My vote is leave it as a combined section but maybe change the title to 'Sportster/Cabrio builds' so that any newcommers don't miss anything.
I wonder if there are any Javelin builders out there that frequent this site?
Peter
9th February 2008, 20:07
Keeping it a combined forum gets my vote too. As Robin says, there aren't alot of Sportster and Cabrio builder around.
Simon
9th February 2008, 23:44
Righto....Forum name changed to reflect the introduction of Cabrio builds.
17th February 2008, 07:25
Thank you all for the welcome.
I've just come back from a weeks holiday and found you've changed the forum name - very nice gesture- many thanks.
Intriguing questions?
JG - Who are you- I've worked out who the other guys are?
Javelin - how many BMW based Cabrios have they sold?
Does the MOC have any record of Javelin sales?
Can we encourage them to join this forum/MOC?
Similarly there must be other Sportster build on going that could be encouraged?
The more ideas the better the build!
17th February 2008, 12:34
Mike, I run Madabout for my sins.
11th March 2008, 22:46
Quick Update.
After months of going backwards, cutting and narrowing the transmission tunnel, modifying a pair of Audi A4 sports seats, widening the footwell, and modifying the pedals and pedal box, this part of the build is coming together. I've had my seats re-covered, and they fit (phew! - it was always a concern they would be too tight): the wider spaced pedals have trial fitted in the footwell really nicely. There is a good sized space between the accelerator and the brake pedal, and the action of all the pedals has been improved by the needle roller bearings and better support brackets.[If you are interested have a look at:
http://www.flickr.com/photos/mikes_bmw_marlin_cabrio/
When I have a bit more time I will learn how to import the odd photo in to this site.
12th March 2008, 12:28
Nice mods to the pedal box. The thing as supplied by Marlin has always seemed a little flimsy to me.
When I "prepared" mine I modified the adapter block that Marlin supplies so that the pedal pushes on the center of the servo pushrod rather than on one side.
12th March 2008, 12:59
Nice mods, I should have done more to mine really!
13th March 2008, 17:38
I am planning to extend the servo push rod (cut and weld insert) leaving the forked end to attach to directly to the pedal: this will leave a single pivot connection rather than the double one created by the adaptor. IThis has the double benefit of lining the pushrod with the servo centre line, and reducing the play in the overall pedal-servo connection.
14th March 2008, 07:59
I thought about this but it then means you have a non-standard servo which is not so good for spares. In fact the Marlin supplied adapter I have is machined (crudely) to accept the end of the fork so that you don't have two joints than can pivot.
If you are using the marlin adapter that fits between the servo and the master cylinder you may also need a little spacer that fits between the servo push rod and the mater cylinder. If you don't the pedal moves about halfway to the floor before anything happens! You can see some pictures on my website.
14th March 2008, 20:42
Good point about the non-standard servo.
I have made my own adaptor, from 5mm plate, and then a pushrod spacer, so hopefully I will not get any excess travel, but until I get it all plummed up I am not sure how much pedal travel I will get.
