27th June 2013, 09:59
Next the dash. school report said always has head in the clouds. Im one of those people who can picture what i want in my mind now im old enough to be able to produce it. Filled and sprayed [/IMG]
27th June 2013, 10:02
I wanted a Walnut dash i can paint but found this and wanted to have ago at hydrographic transfering. a print on a pva background [IMG] [/IMG]
27th June 2013, 10:06
Step two fill container with 75 degree water. my mums bath seemed ideal and as shes on hols no questions as to what i[IMG] [/IMG]m doing
27th June 2013, 10:16
Tape edges of film lay on water for 60 seconds then spray activator wait 20 seconds until film dissolves then lower item at an angle until submerged shake under water then lift and spray with water until residue pva is removed. Not Bad for a first attempt [IMG] [/IMG]
27th June 2013, 10:51
Looks neat. Is the dash thin ply? If so, how did you get the double curve in the centre?
27th June 2013, 10:58
made from fibre glass built it up insections then sanded and filled
there is a picture on a previous page
27th June 2013, 12:24
A+, Young Noob has done a lot better this term. But head still in the clouds...
27th June 2013, 15:58
Very nice, have played with that stuff myself and its quite inredible the stuff you can coat. Looking good.
27th June 2013, 18:46
Nice work.
The dash is a very important aspect of the build imho - it's part of the main interface you have with the car, along with the seat, steering wheel, gear lever and pedals.
I do like your boot too. I wasn't confident enough about my 'glassing skills when I started mine to start cutting big holes in the body so I went for a luggage bay accessed from behind the seats. If I was starting again I'd probably go for a boot lid like yours.
6th December 2013, 16:06
wheel gap
Been busy on the house so car has been on hold but not out of mind. Altered the gap from bonnet to the wheel.
6th December 2013, 18:23
but you cant drive the house!
7th December 2013, 15:58
7th December 2013, 16:01
rear end now level
17th March 2014, 15:07
Time to work on the car again
fun time adjusting the gaps on the front and rear wheel arch
17th March 2014, 15:11
17th March 2014, 15:13
A neat and simple way of doing it. Nice result.
Idea duly stolen....I mean "noted".
17th March 2014, 15:29
I agree, I was going to make formers and cut all the way round... i'll take this one aswell. I assume this will work on the back too.
18th March 2014, 12:20
when doing the front wheel arches I fastened the spacers to some mdf it held everything in place.
24th March 2014, 08:22
hole for speaker Quick doodle wi th the I pad,
24th March 2014, 08:25
